How to change glass screen o 10.1 trio stealth 2g tablet
The screen replacement is available at Amazon. As stated in the description, no instructions included. Nice set of tools included; most not needed. Installation is pretty intuitive; once you see the new screen, you realize that it attaches to the front bevel with adhesive tape, with one electrical connection. You must remove the broken screen basically by gently prying around the edges with tool of your choice. I did see a video of someone using a heat gun to soften the adhesive, but I dared not and used a small hairdryer on occasion. Lots of broken glass pieces will be created, wear safety glasses and work on a protected surface. If I were to do it again, I'd use a shallow cardboard box like the ones on the bottom of packs of soda. This will prevent glass escaping. Be VERY careful when working near the LCD screen, it does scratch easily. Don't worry about the cable, just cut it when removing old glass. Once all glass removed, the Trio will snap open with slight pressure on metal tabs. NO screws involved. Clean bezel well, remove old cable, install new one , reinstall the power and volume piece at the top and snap case together. Simply replace screen by removing adhesive tape and gently pressing screen it in around edges. I think the new screen works better than the original. Be sure both new screen and LCD are clean before the final install. That's how I did it; others might have a better way. Be patient and careful about all the broken glass and it should work fine. Good Buy for money, ships from China but does not take long to get to US. Tracking info is included with the shipping confirmation.
