Sport & Outdoor - Others Logo
Liel Owens II Posted on May 14, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need instructs for quest tent d161on eagles peak 7
Mister Danger
Level 3:
  • Master 5,631 Answers
  • Posted on May 14, 2015
Mister Danger
Master
Level 3:
Answers
5631
Questions
0
Helped
1199169
Points
47629
Maybe this youtube video can help you?
Can search for mor
How to set up 6 man tent
How to set up 4 man tent
I have a ten peaks tent made by quest want to say it sleeps ten with pole color yellow red and black need directions to put it up
https://www.answers.com/Q/Where_can_you_get_instructions_for_the_ten_peaks_tent_by_quest
Unfortunately, the web site given in the link above is no longer in service, so it may be difficult to find instructions other than those at the link.
Quoting from the link above: '
"Ten Peaks Tent by Quest
1) Lay out the tent flat on the ground, be sure to stretch floor to eliminate slack. Drive a stake into each corner loop, then drive the remaining stakes into the side loops.
2) Install the poles by first separating them by their color code. Yellow poles make up the center section. Red poles make up the right and left sides. Slide the yellow poles through the center pole sleeve. Slide the red roof poles through the right and left pole loops of the tent.
3) Raise the tent. Assemble the yellow upright poles and attach them to the yellow roof poles. Raise the center of the tent to its approximate height, by using the quick clamps on the bottom of the yellow center uprights. Assemble the red left and right support poles, attach the support poles to the roof poles. Place the side support poles on the ground near the side stake loops. Adjust the placement and the height of the poles until the tent stands firm.
Need instructions on assembling 2-5 person house shaped tent
House shaped tent is not an adequate description to make erektion suggestions.
Broadly speaking tents are divided into categories of dome, tunnel, ridge, bell or frame.
The ridge tent is sort of house shaped and the classic frame tent also, though this is usually referred to as a bungalow or perhaps chalet tent. None of these types peaks in the centre of the top and neither does a house, usually.
A small marquee peaks in the centre of the top and is also vaguely house-shaped but it seems somehow unlikely you have a small marquee..
It is also important to know whether there is an inner and an outer tent or flysheet and a sewn-in groundsheet, single pole, ridge pole, frame, fibreglass rods or perhaps an A frame.
I can't advise much without knowing what sort of tent you have but I advise you to practice, practice, practice and colour code or number each pole assembly. Bad weather when pitching for the first time is too late to be trying to read instructions and wondering which pole section goes where.
I also advise taking extra pegs and guy ropes in case of accidents or really foul weather. Tents are provided with minimum equipment for moderate weather pitched on hard packed loam type ground.
For different types of ground; sandy soil or rocky different designs of pegs are available and should be used along with heavy stones or sandbags. Double pegging is also advisable in some circumstances.
Preparation and attention to detail is the key to a successful camping trip. No extra precautions often turns a simple camping trip into pure misery. I once camped at the top of a high cliff when bad weather was expected. I double-pegged and fitted extra guy ropes and slept right through a gale while my companion laid awake petrified. The tent never moved but in the morning we were the only campers left on that part of the site.
I need replacement poles for eagles peak 10 x 10 6 person tent
And what would an internet chat room do for you?
How about going to an outdoor store & ordering them
or use the internet to find them
How about contacting the manufacture of the tent
Where can I purchase replacement poles?
Cabela's may be able to special order them.
7helpful
Instructions on folding popup tent
dont remember how to fold up a thomas and friends mesh pop-up tent.
Jul 30, 2009 • Toys
Top Sport & Outdoor - Others Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
