Tablets & eReaders Logo
A
Anonymous Posted on May 14, 2015
How do I reset my irulu tablets password because I forgot what it was?
Mister Danger
Level 3:
  • Tablets & eR... Master 5,631 Answers
  • Posted on May 14, 2015
Mister Danger
Level 3:
Answers
5631
Questions
0
Helped
1199192
Points
47629
You can't get recover it because It is your personal password and without it you simply can't access your tablet. To recover the use of your tablet, you should do a Factory Reset. and yes, you'll lose all your data, so next timetake a good note of your passwors, write it in a notebook (paper, not computer) and keep the notebook in a safe place
Watch and follow this yourtube video about procedure to reset your Irulu tablet
How to reset your 7 inch irulu tablet
5 Related Answers
Anonymous
  • 21 Answers
  • Posted on May 28, 2012
SOURCE: i have a craig touch screen tablet and i forgot my dot password how do i reset it?
Unlock windows password,the easiest way I ever use is to adopt Windows Password Reset ,just a few steps:
Step 1: Download and install Windows Password Reset
Step 2: Burn Windows Password Reset Std ISO file to CD/DVD
Step 3: Put in your newly created CD and remove your Windows Password.
For more details,go to: http://www.windowspasswordreset.net
Gradius2
  • 108 Answers
  • Posted on Nov 13, 2014
SOURCE: How to do a reset for irulu 9 inch tablet?
In order to factory reset your device you will simply need to perform the following steps directly in order to reset your device.
1. Turn your device off
2. Press and hold the volume up button
3. Press and hold the power button
4. Release these buttons
5. Use the volume up and down keys to highlight the factory reset option
6. Press the power button in order to select the option to factory reset your device
mike0862
Mikey
  • 6904 Answers
  • Posted on Dec 26, 2014
SOURCE: I forgot the pattern to my irulu tablet and it
Can you follow this procedure and post back your results? Press the off button for 30seconds, then press the power on and the volume+ buttons together until the reset screen appears! Then use volume to move and power on to select factory reset!
mike0862
Mikey
  • 6904 Answers
  • Posted on Jan 01, 2015
SOURCE: How do I get on to my son's IRULU tablet when he has forgotten the password?
Can you follow this procedure:
1. Turn off the tablet by pressing and holding the power for 30 seconds and tap shut down. 2. Press and hold power and volume up until an android menu appears 3. Use the volume keys to navigate and power to select. 4. look for factory reset and wipe data 5. restart the device and it should be back to factory settings!
let me know how you get on!
jerardi
David Payne
  • 14162 Answers
  • Posted on Mar 19, 2015
SOURCE: I have a irulu 7" tablet ak012 and I forgot my pin code how do you rest it.
Try pressing the power button - volume up button and menu button pressed simultaneously. just press+hold until the system recovery screen appears.
Daughter out a password to get into tablet and forgot what it was
Depends on a tablet but have you tried to connect to PC. Also is it connected to her email account, cuz you should be able to unlock it with it. If nothing else reset it. Good luck
Forgot my password
Hard reset the tablet and create a new account.
1helpful
How to reset my Tablet. I forgot my password.
all you have to do is power it down.
Press and hold + volume button and start the tablet.
It will give you 3 option . Select errase all data and factory reset.
Bang it will reset to factory defaults
How do I reset my Tablet. I forgot the password.
- Turn the tablet off
- While holding Volume Down, press and hold the Power button
- Use the Volume Up and Down keys to highlight Factory Reset
- Press the Power button to select to reset
My irulu tablet will not let me open screen without pin#. I was not given one
If it's an android device...
1. Enter wrong pattern 5 times and wait for 30 seconds.
2. Select "Forgot pattern" and enter your email account username and password.
3. Make sure you use the same account that was used to activate the device and double check the password by logging in to that email account in a browser.
4. If you don't have access to the original email account, you will need to do a hard reset and loose your settings and apps on the devcice. The data on the memory card will not be wiped though.
Note: if you can't remember your email password, you will have to visit the email service support page to get it reset.
also, see here...
http://www.androidtablets.net/forum/android-tablet-usage-tips-tricks/6280-forgot-your-unlock-pattern.html
or here... http://mytabletguru.com/forgot-password-pattern-unlock-of-android-tablet/
Good luck.
3helpful
2answers
Forgot password
forgot my pattern to unlock need to reset
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
