Thats not expert advice,that is rookie advice,
Remotes com Search Results
Replacement Remote for KOSS KS5192 KS5190
KOSS Replacement Remote Control for KS5192 KS5190
now,here is some EXPERT ADVICE! when at flea markets,buy every remote control you find and sell them for 35 bucks a piece on ebay!!
SOURCE: Need Infrared Remote Code...
I had the same problem and it took an act of Congress to solve it. However, I can tell you that through much more hard work and time than it should have taken I discovered the infrared code for my "One-For-All" remote model URC-4021B00 is--0651. Not sure if it's the same for any other remote control models, but give it a shot.
SOURCE: urc-4220 universal remote codes
Eaglescout, URC codes for Koss DVD Players may be 0143 or 0440.
dntom2000, without knowing the manufacturer of your combo player I can't check on your codes, but for you and anyone who needs a code, you can try using the URC lookup page at Philips.
http://www.urc.philips.com
I'm sure you can find a universal remote that will let you change that setting, but you'll have to look around. The cheap ones do NOT let you change very many setting, especially Language setting. Check electronic stores and associates and I'm sure you'll find one that'll work.
