Question about HTC G1 Smartphone
T mob g1 cannot recieve incoming calls
My t mobile g1 can send and receive text messages go on the internet check e mails and make calls
It will not however receive them I've disabled the forwardin to make sure it wasn't that and rebooted the phone and have done factory reset how do I go about fixing this issue
SOURCE:
e-Guru
  • 3917 Answers
SOURCE: Factory Reset for T Mobile G-1
http://www.androidcentral.com/factory-reset-tmobile-g1
Posted on Mar 24, 2009
SOURCE: y cant i send picture messages or recieve them either from my g1
You need to have the interent package to do that. If you dont there are some settings that can bypass that:
Menu > Setting > Wireless controls > Mobile networks > Access point names
Once you get in there, scroll down until you see T-Mobile US and input the following settings:
Name = T-Mobile US
APN = wap.voicestream.com
Proxy = 216.155.165.050
Port= 8080
Username= None
Password = None (delete the 4 digit PW that is there)
Server = Not set (also delete the 1 digit PW there)
MMSC = Unchanged (do not change it)
MMS proxy = 216.155.165.050
MMS port = 8080
MCC, MNC, and APN type all stay they was they are.
Now as far as remembering the old information goes, you can always go into T-Mobile US 160 (right below T-Mobile US), which has all the same settings as T-Mobile US including the password. All you have to do is copy and paste it.
TAAA DAAAA!!!!
Posted on May 13, 2009
  • 229 Answers
SOURCE: I cannot make phone calls, i can receive them and
Check to confirm in security settings under settings > security setttings > call barring service/ that your out going calls have not been barred.
If all is in order, that is no barred calls, then contact your mobile service operators.
Hope this helps.
Posted on Mar 20, 2011
SOURCE: my touch 3g has no service, my messages, my
My I phone 3G Want charge or will not hold a charge,I need all my contacts and I think I sync my contacts. I need help to find on my computer.
Posted on Mar 26, 2011
aexl
  • 212 Answers
SOURCE: HTC HD Desire. Just today I cannot text message
Hi there. It sounds like there is something wrong at the carrier end, not wrong with your phone. Call your providers support line and ask for technical assistance to make sure that the network has no problems in your area. They should have a solution, or at least an explanation for you. Alex
Posted on Jun 24, 2011
Able to recieve text messages but unable to send text messages
You need your message centre number for outgoing text messages. You can find the number by going on your networks website or by phoning you networks customer services.
Hope this helps and please rate
Mar 19, 2011 | HTC 7 Mozart Cell Phone
Phone goes blank
sir is it blinks with white screen only or blinks with white screen then shut down?
-if the phone can receive/send text and mms messages while the incoming and outgoing calls become shut down,i think you need to replace the battery because it is weak.use only original battery.
-and if it is blink with white screen only try to reset all settings or reformat your phone,if not work hardware problem go to repair shop.
Dec 26, 2009 | Cell Phones
Cannot send out text messages.
hi there,
call the customer service of your service provider ( AT&T,Vodafone,Verizon etc)....they will set up message center number on your phone , the one that you have might be incorrect...your mobile operator will send you sim updates that will refresh the settings ....and then you will get the text message options
cheers
Sep 20, 2009 | Samsung Blackjack SGH-I607 Smartphone
Noreply keep send me error everytime i send a text 2 facebook
Hi there
E-mail addresses with "noreply" in them will not receive your messages. They auto-reject incoming mail. Please find the correct address for the recipient.
Hope this clarifies.
Aug 22, 2009 | Computers & Internet
Can receive text but I can't send 1
if you call your service provider they should have the code to put into the phone and then send this should counteract this problem
Jul 19, 2009 | Motorola Mobility Moto Q
I can not send txt from my Motorola W375 i can recieve txt make calls recieve calls but can not send txt i was told 2 change the message centre no. how can i do this?
Somce cell phone carriers can block outgoing texts, separately from incoming texts.. You might want to check with your cell company and see if they accidentally blocked your incoming.
Mar 25, 2009 | Motorola Cell Phones
Help!!
What happens to the incoming calls? Check that you have not set the phone so that calls are diverted to voice mail or another number. Call your service provider and they will probably be able to send you a "service message" that will reset that.
Dec 16, 2008 | Samsung Blackjack SGH-I607 Smartphone
INCOMING CALLS
Hi there, it is possible that you have the G1 set into "always Forward" state, which means when receiving calls the phone will forward the caller to your voicemail.
To Check and change these settings. goto the G1's Home screen, Click the "Menu" button, and then click on "Call settings". Then from here click on "Call Forwarding".
From here, the top setting should say "Always Forward" If this is set to Enabled, click on it and select Disable. This should now allow you to receive calls correctly ! if the Always forward function was disabled already, i would suggest calling T-Mobiles Customer support line to see if they have a remedy to this situation !
Hope this helps ?!
Oct 27, 2008 | HTC G1
Cant recieve text messages
Maybe you never activated the phone to receive txt messages. Call up sprint and activate incoming txt.
Apr 23, 2008 | Samsung UpStage SPH-m620 Cellular Phone
HTC G1 Smartphone Logo
439 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
rrackman
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
