Question about Lanier Office Equipment & Supplies
How to get ink unto drum of lanier ldd130 - Lanier Office Equipment & Supplies
Lanier error code 00
That is the master clamper area. Take off the rear cover. From the rear it is on the right. There is a motor and a rack gear that moves to open the drum master clamper when removing and loading a master. With the back cover removed, try to make a master while watching that assembly. You can also put the drum in and drive the motor by hand to watch and see if opens the drum clamper.
Dec 12, 2014 | Lanier Office Equipment & Supplies
SAVIN C7570 BLACK INK PRINTS FADED (INCONSISTENT)
Hi Linda
Is this ink or toner? Ink will expire if it is on a shelf too long. Toner is a powder that is applied with heat to the paper. It does not expire but will appear faded if the printer is in economy mode or low on toner. on a 4 drum system each drum is independent of the others and can run low or out at separate times. Therefor to save money only replace the empty drums. Have you changed the drum recently? If it is toner try removing it and shaking it, then reinsert it. If you have other boxes of this drum see if you can find a date on the box. ink over three years old may not work well.
Apr 28, 2014 | Savin Lanier Ld275c Lp138c C7570 4 Drum...
Lanier ld 016 drum replacement
Just change the drum unit, a new pcu will automatically reset the copier.
Dec 02, 2011 | Lanier Office Equipment & Supplies
In Lanier GX3000 I would like to print with black ink only. The printer displays to replace the three color ink cartridges.
The printer requires that all of its ink cartridges have ink before printing, the color ink cartridges will have to be replaced.
May 12, 2011 | Lanier Office Equipment & Supplies
Where can I locate a drum for an old Lanier 5235 copy machine and how much? Or is it worth it?
Your Lanier is made by Ricoh and is a model Aficio 355. The drum and drum cleaning blade is still available and not too expensive at about $200 for the pair. You can find these with all the related info at precisionroller.com Great people to deal with and I order a LOT of stuff from them.
Their part numbers are P8150 for the drum and C5950 for the cleaning blade.
Good Luck and Thank You for using Fixya.
Jan 19, 2011 | Lanier 5235 Printer
I have a black line on my copies. i have a lanier 7320 copier. Is it my drum?
It could likely be the drum. Is the line on copies and prints, or just copies? If it's just on copies, it's not the drum.
Jan 18, 2011 | Lanier 1205 Copier
I have a Lanier 7313 Copier which doesn't copy properly. Even with a new ink cartridge, the copies come out faded. Any ideas on what I can do?
This machine goes through developer pretty quickly. Sounds to me like it needs new developer and possibly a drum (and drum blade).
Aug 24, 2009 | Office Equipment & Supplies
How to replace drum unit
open right cover, and front cover. Remove toner bottle assembly (not just bottle), unplug drum (photoconductor) connector. Press the gray/silver release tab and slide out drum. Install and plug in new unit, replace toner assembly, close covers, and the new unit is automatically detected and calibration will begin.
May 25, 2009 | Lanier Office Equipment & Supplies
Jammed Photocopier
you need to remove the drum unit out of the machine,and take cotton rag use achohol ..rotate the drum clock wise until you see the label that stuck on it..
good lock
Feb 28, 2009 | Lanier Office Equipment & Supplies
HP 2840 is printing light even after putting in a new cartridge
no, that is not the drum, it has a chip on each toner cartridge that send information back to the printers main computer, and that tells the machine how much is remaining.
Has the cartridges been refilled ? need to know before i move unto the answer.
Jan 03, 2008 | HP LaserJet 2840 Printer
64 people viewed this question
Top Lanier Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
gggg
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
