Lincoln Mark VIII wont start
if you tried to jump the veh. when the batt. died, then you may have fried a fusable link in the harness. use a test lite to (CAREFULLY) look for voltage leading away from the batt. also you may want to check and see if someone can hear the relay click on as you try to start. (it is sometimes hard to hear it, so you want minimum back ground noise). good luck!
