We use the Marantz PMD580 in our Board Room. The device is rack mounted but not network connected. It is manually operated. The device is not in a state that locks out the keys.Only when we try to record a file do we encounter the unlock message.
To start voice recording, follow these steps:
1. Press the Menu button to return to Main Menu.
2. Select Voice
3. Press Play/Pause to start recording.
4. To pause recording, press Play/Pause again
5. To stop recording, press Select. A pop-up window will appear on the screen. Select Yes to
save recording. The recording will be saved in the RECORD/VOICE folder.
6. Press '<< button to return to the Voice Menu.
Please leace feedback
Cheers
Andy
Problem solved! We discovered that someone had changed the record format from Analog to Digital. As soon as we changed it back the problem was solved. :)
