Technics SL-1200MK2 Turntable Logo
r
ryan mason Posted on May 13, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi i would lick to send my tone arm and base off to be anodised they have asked me what metal it is made of can you please tell me also the pop up light shell.thanks
Audio Service Clinic
Level 3:
  • Technics Master 924 Answers
  • Posted on May 13, 2015
Technics Master
Level 3:
Answers
924
Questions
Helped
351439
Points
1710
The tonearm is probably aluminum, which can be anodized(I think) You can look it up on Google. The illumination for the speed, is probably chrome plated plastic. The tonearm is not made by SME. You also have to consider the tonearm wires. They are fragile and very small.
  • Audio Service Clinic May 22, 2015
    Just thought of something. Anadizing is only for aluminum. I believe irriditing is the process for steel. If you still interested, I can check the tonearm as to whether it's steel with a magnet, HOWEVER, if it's stainless steel, it's not attracted to stainless.
Ben Armstrong
Level 1:
New Friend:
  • Contributor 2 Answers
Ben Armstrong
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
403
Points
5
The tone arms on 1200s and 1210s (un modded and basic version) are made by sme. I suggest visiting their website for full spec
Geoffrey White
Level 3:
  • Master 3,965 Answers
Geoffrey White
Master
Level 3:
Answers
3965
Questions
Helped
914984
Points
10651
They are asking this because anodising is especially suited to aluminium alloys, but not to steel.
Anodising can be done in various colours and finishes. Steel can be chrome plated, shiny or dull, and also plated with other coloured finishes such as cadmium.
The tone arm in this photo of the SL-1200Mk2 looks to be chromed, which means it is steel. To find out use a small magnet at the midway point to see if an attraction can be felt.
http://www.mds975.co.uk/images/vinyl_heaven/sl-1210_04.jpg
  • Audio Service Clinic May 14, 2015
    Just thinking about this again, the base is definitely aluminum, the tonearm shell may be steel, but if it's stainless, it's not magnetic. The outer part of the pop-up is probably made of the same material as the tonearm outer material. I think I have one of those. If I do, I'll let you know. My opinion, for what it's worth, leave it alone, or paint it, if you really have to make it unique.
1helpful
Hi i have a sanyo tp825du turntable and the platter keeps spinning when tone arm is at rest. What is the issue that causes this and what do i need to do to fix it. Thanks guys.
When the tone arm returns to its base it should contact a small micro switch which turns off the motor. Going underneath the platter you should find the switch, either bent out of place or broken.
1helpful
Remove wiper arm on rear of 1995 cherokee
did you read the FSM yet, (factory service manual)
it covers this.
just the rear arm from out side, not inside door.
click ZJ here
then lick wiper............
bingo, its there, every step.
see page 9, it tells you step by step, outside arms.
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
1helpful
Wurlitzer jukebox 1015 78rpm records needle does not start at the begining sometimes starts 1/2" in. How do I adjust tone arm
If you study the screws around the cradle that the tone arm sits in you will see that it is adjustable. This determines where the tone arm is when the record comes up. If the machine was always wrong like this it may have been set for 45rpm records. You need to adjust the whole tone arm post with the screw that goes up into the base of the post..
1helpful
2answers
Uniden cordless phone with answering machine sends out FAX tone
Try disconnecting the power from the back of the base. Then press and hold the delete key while reconnecting the power. When power comes back on press play one time. If that does not work, your unit needs to be replaced.
Single wheel will not lock into place
The first thing I would suggest would be to make sure the black knob above the front wheel is not pushed in but popped up. Secondly, I would try to clean the front wheel fork and inside the base. This is a routine procedure to upkeep the stroller. All you need to do is wipe down the short metal stick that locks into the base of the stroller and inside the base itself and then put some Vaseline around the short metal stick and inside the base. Hopefully, that should do the trick.
Corrosion
sounds like the acid level in your sweat is high a lot of watches onlly have a light plated skin over base metal. if you look at whats scraping you you will see the edge of the surface metal and the base metal . if this helps please rate.joe
I have a Numark TT200 turntable and when unscrewing the tone arm assembly I noticed a broken black lead. The other three were intact (red green and white). How do I fix please?
Turntabletech.com rewire it thats the option or get the TT200 tone arm base its $149 might as well get a new one with that right?
Sending an email with an attachment/error message
You can only send so much html (hyper text markup language) over a Yahoo personal email account. Try toning down what you send, it true that Yahoo mail support 10Mb transmissions, but what they don't tell is they base that number on text being sent. If your problem continues call here:
Customer Care
http://help.yahoo.com/
1-866-562-7219
anaanymous
Oct 06, 2008 • Yahoo Mail
1helpful
Fisher turntable M-720 need to set weight and return levels
Hi mariahom
Setting the tracking force is an easy task. Try this method.
  1. first thing to do with the tone arm sitting above its rest, rotate the weight on the end of the tone arm until the tone arm is balanced in the middle. neither up nor down, just right in the middle.
  2. calibrate the numbered rotating collar on the weight so that 0 is exactly on the reference line on the tone arm.
  3. then turn the weight and numbered collar together to the tracking force that you are seeking. Most moving magnet cartridges need at least 1.5grams of weight. Set it for 2 grams if you are unsure of what your is or needs.
  4. adjust the anti skate dial(if you have one) to the same number as the tracking force you are using.
At this point you should be able to gently bounce the tone arm on your index finger(not above the record of course). This is about all there is to it.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
1helpful
2answers
Sending tone
hi m8 i can tell you that der is no way how stop tht tone wen u send messages i asked samsung and they said no for ma fne
hope this helps
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
