Roland Boss BR 900cd Digital Recorder BR 900 Logo
t
thomas coard Posted on May 13, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i transfer recording to my laptop - Roland Boss BR 900cd Digital Recorder BR 900
ka4iup
Level 3:
  • Master 4,062 Answers
  • Posted on May 13, 2015
ka4iup
Master
Level 3:
Answers
4062
Questions
0
Helped
1095371
Points
51404
Use the USB cable and follow the instructions in the user manual. You can download the manual and updated software from here:
http://roland.com/support/article/?q=downloads&p=BR-900CD
How do I transfer track data to computer?
Why you have to convert to mp3 ?. Did not the card can be removed and installed on the computer and then copied?
Where you convert the file? BR or computer?
What software you use to convert?
1helpful
I can only hear static through the headphones on my Fostex MR16. The recording sounds fine when I transfer to computer, but I can't hear myself playing.
They make headphone amps that will take a line level and boost it in volume until it can drive headphones. I'd get one of those, and plug it into any available "line out" or "rec out" on the back of your Fostex. Sounds like the D/A converter section that feeds the headphone output has gone bad, and my solution will get you around that.
How to transfer recorded songs from ctk 810in to sd card
I want to practice through key board by singing along with with the help of SD card. How can record my favorite songs as karokee in SD cart to play in the instrument.
Oct 22, 2011 • Casio Music
2helpful
How can I send recordings to my laptop? I have a usb connector and i want to connect my portable grand to my laptop but the laptop does not detect the piano and i don't know what to press on the piano...
Hi mjaynneb,
I could be wrong here but I have a number of keyboards and the USB connection is usually for Midi control from software like Cubase and the like. If by recording you mean recording Audio then I think you'll find that it won't be possible using the USB port.
Midi is great and I use it a lot. It enables you to arrange music using your computer. Also you can record the music you play on the Keyboard on the computer as Midi. This means that the computer can play back through your arranger what you just played. Bear in mind though that Midi is purely numbers that represent notes, velocities and note duration so is not actually audio.
My keyboards have the ability to record to SD card or a Hard Drive, however if this is not a feature of your arranger then probably your best bet for recording audio from it is by using the Audio out ports of your arranger and using a connecting lead to a good low noise sound card on your computer. As you are using a laptop you can find external usb sound cards/interfaces so that should do fine. Then you could probably use something like Audacity which is free software, to record to a wav file.
I hope this helped.
Kind Regards
mparkyn
How can I save my recorded track in CASIO CTK 810 IN for future use. I can record one performance but cannot save it for ever, if I record another one track the previous one is got deleted. Is there any...
Recording a new tune automatically deletes the previous one.
Solution transfer the recorded song to your computer via USB cable.
It is also possible to store up to 5 additional tunes in the song bank
See page E50 and appendix 9 of the user manual available here. http://support.casio.com/pdf/008/ctk_810_01_e.pdf
I have same problem. I have recorded my performance on keyboard (PSR I425) when i transfered it to PC it's in .bup format. and the file is not getting played on PC. how should i solve it?
Transfer the data in MIDI format. The BUP format is a proprietary format to the keyboard and can ONLY be played by the keyboard. Either dump the data as MIDI format or using a MIDI interface send it to the PC or lastly, capture the audio using an audio interface on the PC.
2helpful
3answers
My Fostex mr8 hdd "full"
If you can reformat the drive after dumping out anything you want saved MIGHT fix the problem...
The unit MAY not be able to tolerate fragmenting when you delete a snippet here and there... It may require large blocks of contiguous space.
Reloading backed-up song data on Boss Micro BR
Are you transfering from one disk to another on your computer? There is a possibility that the format of the original disk is not being recognized.
1helpful
I want to know how to set up a master on my tascam dp02
first set the in and out points of song make sure your holding down the shift key while setting in and out points.then pres shift key holding down on it pres master key it should start flashing.then pres record play.good luck
3helpful
Transfer recording from technics piano model sx-pr602-m to comput
the correct way to transfer files from the piano to a computer is via the MIDI out socket on the piano ...not the jack
you may possible need a midi to usb convertor ...which readly available and cheap
Feb 01, 2009 • Music
Top Roland Music Experts
NOEL
NOEL
Are you a Roland Music Expert? Answer questions, earn points and help others
