Sony Playstation 3 (PS3) Console Logo
Posted on Oct 24, 2017
When PS3 boots the screen turns green with white dots
After the PS3 boots everything looks fine, but after about 1 to 2 minutes the screen starts to flicker with green and white dots then the screen stays on with the same green and white dots. After a few more seconds the system freezes. No sound, no movment, nothing, I can still see a shadow of the PS3's menu "behind" the green and white dots.
Mariyan Valev
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 5 Answers
  • Posted on Oct 24, 2017
Mariyan Valev
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
5
Questions
0
Helped
2081
Points
15
Emergency cooling should be cleaned. If not cleaned, you risk expensive repair.
5 Related Answers
Anonymous
  • 207 Answers
  • Posted on May 27, 2008
SOURCE: PS3 either won't turn on, or freezes immediately. HELP!!!!
OK it sounds like a problem I had with one of the units that came into my shop, I do believe you will need a new part which means you will need to break the seal. I suggest you call sony and see what they say and what they will do for you. 1-800-345-SONY (7669)
If they want to charge you id say forget it and try it yourself.
i can send you a guide to help you fix it.
I am thinking a sensor board or a power supply could be others and its hard since its not in my face but let me know what sony says and letss fix this baby.
I do also buy broken ps3s and can help you find a steal on a used or new unit!
Anonymous
  • Posted on Nov 12, 2008
SOURCE: PS3 - Screen Flicker
You need to try a new HDMI cable.. Cheap HDMI cables do that? I had the same thing happen to me... I switched the HDMI cable and it fixed mine.
AV
Anonymous
  • 174 Answers
  • Posted on May 18, 2009
SOURCE: At the startup menu the Playstation 3 freezes and white dots so up on the screen
seems you have a problem with your graphics chip, and needs repairing.
FixMyConsole
benwabnick
Ben Wabnick
  • 2404 Answers
  • Posted on Jan 04, 2010
SOURCE: ps3 wont go past searching for network and just show white dots
Sounds like a problem with the network adapter if its not able to detect your network as long as your network is working with your computer.
Anonymous
  • 66 Answers
  • Posted on Mar 25, 2010
SOURCE: my ps3 starts and will run a game for a few
Be sure to folleow these instructions to the letter, you could damage your PS32_bing.gif if you choose the wrong option! I do not take any responsibility! Please proceed at your own risk! If you read and follow the instructions exactly you should not loose any data! Feel free to ask questions if you are confused so you don’t make a mistake!! Sorry, I had to say it, I don’t want anyone mad at me if they make a mistake, don’t back up their data and erase it, and then blame me…
The current version of the ps3 firmware has a “recovery console”.
You access it by
1. Start with having the system in standby (redlight is on)
2. Hold the power button down; the system will turn on and turn off once again.
3. Press and hold the power button again and keep holding, it will beep as it turns on and then it will double beep. When you hear the double beeps immediately take your finger off the power button (if your system turns off before you get a double beep just try again and hold the button, it should double beep the 2nd time you try)
4. You will be prompted to plug in your controller via USB and then hit the PS button
You will now have a screen with these options
1. Restart System: Restarts the PLAYSTATION®3 System.
2. Restore Default Settings: Reset all system settings back to default.
CHOOSE THIS ONE 3.Restore File System: Checks for corrupt/missing system files.
4. Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
5. Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
6. System Update: Update the PLAYSTATION®3 System
IT IS VERY IMPORTANT THAT YOU DO NOT CHOOSE THE WRONG OPTION HERE OR YOU WILL LOSE ALL YOUR DATA. The one that fixed my blu-ray drive is option 3: RESTORE FILE SYSTEM
I REPEAT CHOOSE RESTORE FILE SYSTEM
After this, it is going to restart and bring up a screen reading something like “you have Corrupted System Data. Your PS will now replace this data” Then you choose continue and that should be it.
This option reinstalls the system files and drivers inside the PS3 with the original ones that are stored on your hard drive. In this case, it replaced a corrupted driver for the blu ray drive thus fixing my issue and hopefully yours!! This option will only replace all system files thus saving you from loosing any data that’s stored on your hard drive. Again this option does nothing to your hard drive it reads a file from the drive and rewrites it to the PS3 system.
Here is a video of the recovery screen.
www.youtube.com/watch?v=m0SPmkV-jco
If you want a more technical understanding of what this is really doing continue reading. DO NOT NEED TO READ THIS TO COMPLETE REPAIR. The PS3 does not boot from your hard drive as a computer does. It has a flash memory like a cell phone that stores all system files and system firmware updates that you get when the PS3 updates. This is why reformatting your hard drive will not fix your problem, none of the system files are stored on your hard drive (ex. XMB, system firmware, etc.) nor do they run from the drive. However, your hard drive does contain a full backup of your SYSTEM files and thus when you choose option 3: RESTORE FILE SYSTEM it rewrites the original system files from your drive (which aren’t corrupted) back to the flash memory, which is corrupt, thus solving the problem.
Gx620 boots up, then screen goes blank, reboot gives blank screen with cursor blinking. will boot with cd but still shuts down after a minute or two.
Remove the battery and open the case. Look inside the computer with a flashlight to see if any of the capacitors are busted or leaking from corrosion. The capacitors look like little battery towers, but they are not as tall as the AA or AAA batteries.
If the capacitors are bad, your computer goes bunkers.
My Xbox 360 is fuzzy and has green dots all over the screen
I doubt it's the 360 since everything else is working just fine. The menu works fine, the game works fine. However if you downloaded one of these maps from the marketplace it may be corrupt, and you will have to delete and re-download the map pack.
Green screen:s
you need to take it to a shop and have them look at the video card and the cables and see if either are faulty. there is nothing you can do on your own.
1helpful
Mitsubishi wd52525 problems
i have thought about this since you first posted it. if the demo is good then the light engine is ok. it sounds like a problem in the chassis. probably on the DM and the terminal board. to repair the chassis would cost about $250.00 plus shipping.
go to www.tv-techs.com
PC or monitor, signal problems
your monitor is telling you it's on it's last legs..either that or your compaq has a bad video section. either is more vital than a video cable being loose.
1helpful
2answers
Green dot's and pixelation via hdmi
its the ps3 u have to send it back to sony! the green dots will get worse and start to freeze up ur system i had the same problem last month!
2answers
Green dot in middile of my screen
The green dot in the center sounds like a burn mark on one or more of the picture tubes inside the set, and the curved lines are telling me that you have a problem in the convergence circuits. The blue haze around everything white tells me you either have a lot of dust build up on the lens over the CRTs, or your picture tube(s) are very weak. If this set is over about 12 years old, I would replace it. I doubt if you will be able to get the green dot out of the picture without changing the tubes which would be VERY expensive.
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
