Hi Samantha
Assuming that the WiFi is working around the house with other devices like iPhone / iPad and other computers?
The Westinghouse TV is just another device connecting to your Home Network via a WiFi Signal. Unless it uses a dedicated Ethernet Cable at the back of the set > to Modem Router Box.
So... the problem would require setting up the Westinghouse smart TV with the necessary settings.
Netflix is just a web site and will become available when the TV connects to your Network & External Internet GateWay.
First, you need to know your WiFi Name & Password.
I find it easier to use the iPhone as a test device to check the WiFi signal and set up details first. To Test Password etc.
There is a helpful tool on the App Store called iNet - Network Scanner - See Below
So... you must find the settings for Network on your smart tv.
Setting the tv for DHCP is allowing it to Automatically search for an internet connection. Thats what most people do.
Just choose your WiFi name (SSID) & Password.
But... you can choose your own IP addresses if you like to keep all your devices on a known address.
Eg. Your Router or Modem Box Gateway address 192.168.1.1
Each of the other devices have a unique address.
Computer 1 192.168.1.10
Computer 2 192.168.1.20
Camera 1 192.168.1.100
SmartPhone 192.168.1.130
You can use the end numbers between 1 & 255
Your Gateway might also use another IP Group e.g. 10.0.0.0
Your really only interested in making the last numbers different from each other.
Hi Penny
Not exactly sure of your requirement.
An Activation Code usually refers to enabling a paid for service.
Like a game or streaming service like spotify etc
AppleTV is plugged into your TV via an HDMI Cable.
It then accesses your local in home WiFi....
To connect to the internet and your Apple Account.
You will need your WiFi Modem password initially to connect into your home network.
Then set up the AppleTV to connect to your Apple Account with your Apple ID (Username & Password)
Use the free Apple "Remote" App on your iPhone to make it easier to enter text.
Also, this might be good for entering activationcodes for joining any App services shown on Apple TV main menu.
To connect your Iphone to home wifi you should go into the 'Settings' app then there should be a option where you can click on 'Wi-Fi'. If the wifi is on you should see green next to wifi. Under 'Choose a network' select your home wifi. If it is password protected it will ask you to put in your password, if not it should automatically connect.
Not enough details
Plug the AppleTV HDMI cable in and connect it to your TV Screen.
Use the TV Screen remote control to select the screen "input" from the HDMI port you plugged in to.
Turn AppleTV on (plug in) http://www.apple.com/appletv
The details should show on your tv screen if the correct hdmi input is chosen.
Use the tiny aluminum IR (IfraRed) control to enter details & control your AppleTV.
If you have an iPhone / iPad you can get the "Remote" App for free that is easier to use to set up the ATV.
AppleTV will want to connect to your home WiFi (Modem) Box that you get your internet from. You will need to know the WiFi Password to allow connection to home WiFi. This keeps the neighbours from connecting to your wireless internet.
You then Select the Language and enter your AppleID (e.g. email address & password) same as you use for your App Store for iPhone / iPad etc
Once connected to the internet the ATV will show all the streaming services that are available. Also if you have iTunes on your Mac Computer you can set up sharing and display selected photos as a slide presentation when the ATV is in standby.
There are many sites for troubleshooting ATV.. here is one
By no network coverage do you mean no cellular signal or can't connect to your home wifi? If wifi trouble push settings button on iphone. Select and turn on wifi. It will search for available wireless networks. Choose your home wifi, should be the strongest signal, most bars. If you don't know your ssid , look on the sticker on the modem. For instance ssid at&t 2345. Once you select your ssid you need to enter password which is also found on the sticker on modem. Enter password and select join. You should now be connected to your wifi. This will always reconnect automatically when you leave and come back home. If not wifi issue, are you just too far from cell tower to get good signal?
connect pc to modem with ethernet cable. open web browser and in the address bar type 192.168.1.1 this should bring you to the home page of the modem. for user and password type admin if this does not work try admin and password. then go through settings and change password and save.
