Can the same hoses/power heads from an older Electrolux 1521 be used on a newer Electrolux Epic 6500 SR?
SOURCE: Electrolux Epic 8000
YES,JUST TAKE OFF THE HEPA FILTER.
IF I MAY SUGGEST,IF YOU WANT TO BUY AN AREUS/ELECTROLUX YOU MAY WANT TO LOOK AT THEIR "BOTTOM OF THE LINE" MACHINE, THE "CLASSIC" IT'S HALF THE PRICE AND A MUCH BETTER DESIGN THEN THE NEW "FLAGSHIP" MODEL, WHICH IS COMPLETELY DIFFERENT THAN ANY PAST ELECTROLUX. IT'S BULKY,AWKWARD TO USE. EVEN IF YOUR BUYING FROM ANOTHER SOURCE, GO INTO AN AERUS DEALER AND GIVE THEM A TEST DRIVE.
I CLEAN APARTMENTS FOR A LIVING AND AM VERY FAMILIAR WITH ALL ELECTROLUX MODELS.
GOOD LUCK!
SOURCE: Repair manual for Electrolux EPIC 6500 SR
I don't have a manual for these but the trickiest thing about these units is taking them apart. If you have an Aerus/Electrolux dealer near you, it's not a bad investment to have them install the motor for you. You would probably receive a warranty with the work, and the things a long time. Great return on investment. But if you are determined to do it yourself, open the front of the canister and remove the bag. As you are looking at the front of the unit, there are two vinyl coverd strips that run the length of the unit. Pull forward on these strips and then pull out so that the vinyl seperates from the plastic underneath. Now grab the plastic strip with a pair of needle nose pliers and pull towards the front of the canister. These can be tough if the machine has never been opened up before, but pull as hard as you need to, to slide the strip out. Once both strips are out, turn the machine over, pull out on the sides of the bottom of the unit, and lift up. The bottom should come of relatively easily, and eveything will be exposed. Good Luck!!
SOURCE: I have an Electrolux EPIC 6500 SR canister. The
try pushing the cord back in whilst depressing the retract button
