Question about Bosch Maxx 6 WAB28260GB White 600 mm Washer Front Loading, 6kg, A Energy Rating
How do i fix a bosch maxx 6 washing machine that wont take the conditioning liquid please?
  • Bosch Master
  • 3,042 Answers
Owner's manual? no Manual try manualslib.com
Posted on May 12, 2015
SOURCE:
My Bosch maxx 6 do not wash the clothes
Please be more specific with your problem. Does it even start? Does it have power? Does it fill with water? Does it spin or agitate. Help me isolate the problem.
Nov 30, 2017 | Bosch Washing Machines
How do I fix my Bosch Maxx 6 washing machine. The drum wont rotate? Can I reset it?
Check the drum motor power supply if its OK then problem can be in the control box try to figure out the trouble. And trouble shoot it
Jul 19, 2016 | Bosch Maxx 6 WAB28260GB White 600 mm...
What is error E:00 in Bosch maxx 6 washing machine?
error E:00 in Bosch Caroline, Could not find anything pertaining to this Bosch code. You may be can contact Bosch at last link posted or download manual.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Identify Bosch Washing Machine Error Codes
How to Identify an Error Code on Bosch Washing Machine
Washing Machine Error Codes Front Load and Top Load Washers
Download instruction manuals
Apr 02, 2016 | Bosch Maxx 6 WAB28260GB White 600 mm...
WHY IS my bosch maxx 6 CANT SPIN THE CLOTHES OR DRAIN THE WATER ?
Hey there, welcome to Fixya! The above answers were pretty helpful, did you fix your problem with them? Did you check the manual for further instructions? You can find a PDF copy here: Bosch Classixx 5 Manual
Jul 11, 2014 | Bosch Maxx 6 WAB28260GB White 600 mm...
I'm having spots comming up on some washing, Bosch Maxx 900
This video will show you how to change a door seal on this Bosch Maxx 900
Jan 11, 2010 | Bosch Washing Machines
I have a dirty rubber inner Bosch Maxx 1200 Front Loading Washing
First clean around the rubber with some mould and mildew cleaner for bathrooms - available from most supermarkets.
This is a natural accumulation of waste detergent, fabric softener, fibres and dirt build up that is being attacked by bacteria and eventually decomposes into a sludge / goo and then eventually starts smelling bad as well.
To keep the machine clean of waste build up and to keep any bad odours away:
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
7. Repeat the cleaning procedure monthly
Oct 02, 2009 | Bosch Washing Machines
Maxx 1000 wo;nt spin
check brushes in motor 6 years quite good.
Sep 14, 2009 | Bosch Washing Machines
Bosch maxx wfl 1300 washing machine that wont start.
hello could be brushes on the motor. there are 2 black clips that sit on the motor after time these whare down just slide them out and slide new ones in good luck
shaun
Jul 21, 2009 | Bosch Washing Machines
Bosch Maxx 6 WAB28260GB White 600 mm Washer Front Loading, 6kg, A Energy Rating Logo
260 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
jimorris77
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
