Computers & Internet Logo
A
Anonymous Posted on May 11, 2015
I WALK AWAY FROM MY LAPTOP AND COME BACK IN A FEW MIN TO IT BEING SIGNED OFF IN SUSPEND MODE ..HOW DO I SHUT OFF SUSPEND MODE COMPLETELY?
D. E. Hev
Level 3:
Genius:
  • Computers & ... Master 1,187 Answers
  • Posted on May 11, 2015
D.  E.  Hev
Level 3:
Genius:
Answers
1187
Questions
Helped
424315
Points
5819
1helpful
How to open hp laptop in sleep mode
This is a common problem on HP computers but also has many causes. If your laptop is not coming back on after being put into sleep mode, it could be a software issue among a few other things. If your computer has a hibernation mode I would suggest using it to get around the sleep mode issue. This mode will save everything the way it is and shut down completely. When you restart the computer it will open up just as you left it. Just like sleep mode except with a restart. This does not solve the sleep mode problem but easily provides a power saving alternative to it.
My hp 2133 powers on but the power led doesn't light up I don't have any indicator as the power led blinks whenever I put my laptop to suspend.
can you just please completely remove your laptop battery --- keep it away for couple of minuets then put back run the pc i hope the problem is gone
2helpful
2answers
Green battery light on the archos 5 but when i disconnect it from dock or usb no green lights abd completely dead - won't switch on either in dock or out???
Power green LED light should come on, CHG green LED light should also come on showing the battery is being charged. Leave your unit in Suspend mode while charging it, DO NOT turn it completely off as "Shutting Down.." because it will not charge your battery.
I just purchased an almost new Archos 5 on eBay recently, and the first day I had it, happened to me that I left the unit off and charging on the Mini Dock with external AC power supply, after 13-14 hours the CHG light still wasn't blinking. Then I though maybe I have to leave the unit in Suspend mode rather than completely off, which I did, and in a matter of 3 hours it fully charged the battery.
Again, do not shut down completely the unit, leave it on Suspended mode, or even on, and connected it to your mini dock, after a while the screen will go blank the unit will go into Suspended mode by itself, and after 3 hours on external power supply or 8 hours via USB on PC should be completely charged and your CHG light should be blinking, indicating the battery is charged.
I hope this helped.
3answers
Screen goes black when turned down and it does
try removing suspend on lid close .. refer to your laptop manual .. try this too disable herbernation also ..if nothing works check if you have latest graphic driver !! it might be a problem with ACPI .. but my two solutions should work !!!
Shut lid without logging off properly know it will not start up
Your pc isn't recovering properly from Suspend mode.
If it's an XP laptop I would recommend changing the Power Management options to Hibernate than Suspend. If it's a newer Laptop, than Hibernate won't take long to recover. I had to do this with my new Netbook.
Spilled pop on laptop now completely dead
YEP! Walk away from the laptop. You killed it! And it will be costly to fix!
Estimate that at least a keyboard, and probably a motherboard will have to be replaced. That is almost the whole computer. Better bet- buy a new Toshiba Toughbook - that is practically impervious to the spilled drink. But expensive!
Yesterday, I left my computer to talk with a
I would need some more information to completely help you. When you say you walk away and the pc shuts down and starts back up, does it close down (reboot) or does it go into screen saver / sleep mode? What button did you push for the power button light to blink? Have you put the PC into sleep / hibernation mode by pressing the power button once.
Broken power key compaq nx9010
It is fine to leave it on 24/7 if you configure the power options so it can go into suspend or hibernate mode, then it will not overheat. Click on start>control panel and Power Options. You see some options to suspend/sleep after so many minutes or if you close the lid. You use that option if you are going away from it for a couple of hours. There is also an option to put it in Hibernate mode. This is the mode to put it in when you go to sleep at night. Both of these options will slow it down enough so it does not overheat. Some people use these options and keep it on 24/7, no problem.
Don't forget to rate this 4 stars before you log out.
Laptop Screen dark yet computer works with external monitor
does the fan work ok? and do you have a laptop holder for it or you just have it on a desk ....get a laptop holder for it if you do not have one and as for the rest goto the power mangment area on the computer and see if the monitor might be on stand by after a few min ...
Screen went black
When you close the lid, there is a small pin that engages the case and flips a switch to tell the laptop the case has been closed. The monitor will ALWAYS turn off then, because otherwise, the heat build up would burn the screen! Do not try to defeat this, replacing an LCD screen is usually more expensive than the value of the laptop!
Now, that all being said (and please remember), the situation you have now is (hopefully) just that the laptop tried/succeeded in going into ACPI "suspend" or "hibernate" mode.
1. Remove all cables and 10/100. Remove all USB devices. Just leave the PSU (AC power supply) connected.
2. Press the power button firmly, JUST once. Wait. And I mean WAIT, because some laptops can take 2 minutes or more to come out of suspend/hibernate, if they were very busy at the time it was shut down.
3. If the LCD screen lights up. you are done. But if it does not light up now, then proceed to step 4.
4. Press and HOLD the power button down for 10 seconds. This forces the laptop to shut down completely, even from suspend/hibernation. Some unsaved files may be lost, but tghe laptop goes cold, so you can start ACPI over again.
5. After a few minutes, press the power button again, firmly, just ONCE and for 1 second max. Laptop should start up OK.
6. Once it starts up, go to START MENU/SETTINGS/CONTROL PANEL/POWER SETTINGS and search for the "hibernation" tab. Turn hibernation OFF. your laptop obviously has some problems or lack of responsiveness with hibernation (most do). Use suspend, instead. It is much safer,. faster, and still does a good job of saving HDD and LCD wear. Please let me know how this goes for you, there are other more detailed problems that may be involved here, but I suspect this is most likely.
Grand Canyon Tech
Grand Canyon Tech
