2006 ram that shakes in the front end when brakes applied and going around 40 mph. Ok at lower and higher speeds. Shaking is really bad when brakes applied at higher speeds. please help.
check and test front hubs [wheel bearings ] --engine shake poor performance can be quite a few different things ---have scanned for any trouble codes----some reasons needs tune up -pulley failing --failed motor mounts--sensor failing--fuel delivery etc
a good thing to check would be your inner and outer tie rod ends. if they are going bad they will cause a lot of shaking in the car and will also cause the front end to be out of a lined which will make your tires wear faster and uneven
If it shake only when the brakes are applied, then it is a brake issue/ uneven wear on the pads & discs.
There are upper and lower control arms, but if they are bolted tight, it shouldn't be the issue. If you hear clicking, check out you CV joints.
Have you rotated you tires? Patterns can wear in and cause lots of shaking.
try the simple solution first put your front tires on back and back tires on front. check your air pressure then take it for a drive and see if any thing has changed. if so you probably have a badly worn tire. if no change have someone move the steering wheel back and forth wyle you are under the fornt of the car (dont forget to chalk the wheels) and see if any of your steering components are loose/moving. if nothing is loose and your tires are good try to bounce the front end. if you can really get the front of the car going up and down pretty easy you havce bad struts/shocks.
You seem to have more than one problem, first of all the balding tire you have a negative camber problem that can be adjusted by getting a wheel alignment done. The shaking problem while applying brake could mean that you have bad/warped front rotors. It can also mean bad Tie rods. Lastly it can mean that the front tires needs to be high speed balanced. Good Luck
