2010 Honda Pilot EX-L Logo
mario blaise Posted on May 11, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I remove my factory radio from my 2010 Honda pilot and install a Rosen dshd0850p11 . since the installation, my AM frequencies stops working and my Sirius option as well?
The AM frequencies and Sirius stop working after i install a rosen model #dshd0850p11
MATT
Level 2:
Sergeant:
New Friend:
  • Expert 126 Answers
  • Posted on May 14, 2015
MATT
Expert
Level 2:
Sergeant:
New Friend:
Answers
126
Questions
0
Helped
44998
Points
507
I am a installer at southernelectronics.com, I have seen many of these rosen radios with the same problem as well and the nav screen locks up. Every time ive tryed to call the company they have told me to send it back and it would be 6 to 8 weeks to check it out. needless to say I don't recommend this company.
A
Anonymous
Your replacement radio is defective. Full stop.
Necesito el codigo de radio de un honda pilot 2010
Hola Moises,
  • si est? desconectado un aparato audio con protecci?n contra el robo de energ?a el?ctrica, debe especificar un n?mero de c?digo ?nico dentro de la unidad o no funcionar?. Este c?digo y n?mero de serie de la unidad de sonido aparecen en el DNI que viene con el veh?culo de lucha contra el robo. La tarjeta se suele colocar en la guantera en el momento de la entrega.
Recuperar su Radio y Navegaci?n c?digo
  • El c?digo se escribe generalmente en el tronco o en la tarjeta de servicio si usted tiene uno. Si no lo encuentra, se le ha para ir al concesionario de Honda. Se abre para usted o darle el c?digo. Escribir y guardarlo en alg?n lugar seguro.
  • Aqu? hay dos enlaces a la Web de Honda
Buena suerte,
JP
https://radio-navicode.honda.com/ Honda Dominicana
1helpful
How do I remove the rear bumper cover of my 2010 Honda Pilot to gain access to the hitch area?
Trailer Wiring Harness Installation 2010 Honda Pilot
Installation of a Trailer Wiring Harness on a 2010 Honda Pilot
Today on this 2010 Honda Pilot we will be installing wiring harness part number 118491. The harness itself is located behind the driver side rear bumper, almost right above the exhaust. First we will disconnect it from the clip that is holding it in place. We will pull it out and remove the cover to the plug itself. At this point we are going to install the wire harness that plugs into it. It just snaps back in. Then we are going to route this over to our hitch, make sure we stay away from the exhaust and we will be okay. :28
We are going to pull it out through the bumper fascia and out by the hitch. Then we can zip tie the wire harness in any way we see fit. Now the rest of our excess wire here, you can zip tie to take up the length as away you want it to be. We have the stuff behind the bumper done, so lets go back in the rear cargo area and start adding fuses and a relay. :50
There is a panel back here labeled Auxiliary Fuse, we will pop that off with a screw driver and there is a little cap underneath there that we need to remove too. It can be a bit of a bear, but there is a latch on the very top that you need to push down and pull back. We have our lid here that shows our fuse locations. On is loaded stock, it is not going to be used since there is not a metal contact on one half of the socket. Lets go from left to right. The turn/hazard one will get the 7.5 amp. Install the one labeled back. Then we will put a 20 amp on the side here labeled small. And then we are going to need to install the relay on this socket here that is labeled small LT. Alright we can put our cap back into place and put our panel back together. Then we are going to move down to the left, to this storage compartment right here. There is another panel in the back, you need to pull that out. Here you can see where our plug in is for a little black box, that will plug into place. We will leave that pretty much alone. Store it in a secure spot, put our panel back into place, and next we need to go underneath the hood. 1:59
We are under the hood now. We need to install this square, 30 amp fuse here. We are going to install it in this fuse panel right here. There are two fuse panels underneath the hood, you want to do the one that is underneath the intake right here, which will be the driver side of the vehicle. There is going to be one open slot, that is going to be where we are installing our fuse, and reinstall our cap. Now we can go to the back of the vehicle and check our install is working. Lets go ahead and test our 4-pole. First thing we are going to do is hook up our ground clamp to our white wire, then we will check our running lights which will be the brown wire. Next, our left turn signal which is yellow. Then we will try our right turn signal which will be green. Then we will do a brake signal which will be green and yellow at the same time. With that our install is finished. There you have it for part number 118491 on this 2010 Honda Pilot.
2answers
My antenna on my 1990 honda accord stopped working after I installed a new radio
BAD CONNECTION? DID YOU PLUG IT BACK IN? OR DAMAGE WIRE? OR PULL OUT FROMM BEHIND DASH
2007 honda pilot radio code
Typically to get the code you have to have the serial number of the unit and call a Honda dealership to get the code. Sometimes in years gone by, there was a credit card sized card that had a sticker with the serial number and code. Sometimes the sticker is even stuck on the owners manual or the inside of the glovebox.
It sound like you are going aftermarket so I would think that the code is not needed as the code was only for the factory radio itself, not the rest of the system (speakers, etc..) Call the radio installer and ask but I don't think you need the code.
The factory radio has been locked out
the dealer is the only one that can unlock a locked radio, they will need to remove the radio, get a "code" off of the sticker on the back of it, and then call the dealers unlock assistance number to get an unlock code. it cant be done with out the dealer. im sorry :(
2answers
Connecting ipod to AUX in car stereo
you need an AUX cable from radio shake. Does your deck have a port in front or in back?
Where is the factory installed towing wiring harness connector located on a 2003 Honda Pilot?
Towing package not a factory installed item in 03. Most likely a dealer option installed.
37helpful
5answers
My radio in my 05' Honda pilot stopped working. The anti-theft light flashes but there is no display. I tried installing an aftermarket stereo to see if that would work but no power goes to that either....
In my case the solution was a fuse on the passenger side inside fuse box. It is not listed as a fuse for the radio but it is none the less. If your cigarette lighter isn't working either its the fuse. On my 2004 it was fuse # 9 a 15A fuse.
1helpful
Factory installed radio/casette player 1992 honda accors
You should disconnect the neg. battery cable and disarm the air bag. Remove the floor console and the front console panel, remove ashtray and ashtray holder, remove 2 screws holding the radio at the rear of the unit, carefully push unit out the front of the dash. When it clears enough, disconnect the antenna and multi pin connector. Remove the unit. Reverse to install. Enjoy the new sound system. countrycurt0
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
