To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability.
Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
Type in the "brand name only" of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
SOURCE: i need to know the code for this television as i lost the remote
Try Hifi remotes .com bunch of codes there
SOURCE: the power button on the tv is broken and i lost the remote
You can just try programming the remote with the Sharp codes they list in the instructions until you find the one that works. Follow the procedure for entering a code and try it. When you find the right one it will turn the set on when you hit the power button. The remote's instructions tell you to turn the set on to make finding the code easier (when the set shuts off you know you found the right one), but you can work without it.
SOURCE: Can't turn off SAP/MTS without remote
Dynatron MR 110 available at various sites including Amazon.
SOURCE: universal remote codes for sharp tv, model number
You need the sheet that came with the remote. If the manufacturer's codes do not work with your ??, then you need a more modern remote. The codes must ALREADY be in the remote to be used. The code is part of the REMOTE.
http://www.tvcodes.com/ may have the code for you.
