What type of car? If it is older and uses vacuum for blend door operation, you may have a vacuum issue. Engine vacuum is low at higher speeds and vacuum is high at idle. If there is a check valve incorporated in the system it may be bad causing improper blend door operation. Also make sure the cooling fan comes on during AC operation and the condensor is not obstructed causing lack of airflow across the fins. You will get more airflow at higher speeds whichwill help in the cooling and make it colder while driving
