PrintCopy .infohttps://printcopy.info > code=SC390
Code: SC390; Description: TD sensor error 1. The TD sensor outputs less than 0.5V, 20 s after the TD sensor initial setting has been performed.
Missing: cod ' Must include: cod
Fixyahttps://www.fixya.com > ... > Ricoh
The closest thing is the sc390 code, which means either the toner density sensor or the developer has gone bad, and typically replacing the PCU can fix that ...
Copytechnethttps://www.copytechnet.com > 56632-sc-390-a
Sep 24, 2011 - I've got an Aficio 1018 that's generating sc390 after every 10 copies. I recently fitted new drum, cleaning blade and developer and changed ...
Description:Finisher communication error 10
•Communication error occurred between the PRH and Finisher.
•No ACK was received within the specified interval following transmission by the PRH of the synchronization sequence packet. (syn reception timeout)
Precor Error Code 42
Error Code: 42
Manufacturer: Precor
Model: All Models
Error Description:
Error 42, Lift Position Value Out of Range. Error 42 is displayed when the lift position reported by the lift position potentiometer is found to be outside its set limits.
If an Error 42 has occurred, it is important to know the physical position of the lift when the error occurred. It is possible the lift is physically out of range or jammed. In this case, the Error 42 is a secondary symptom and the issue should be approached as an Error 40.
Possible Reason:
Bad or intermittent connection in the lift motor controller.
The lift motor requires calibration.
The lift motor potentiometer is bad.
The lower PCA to upper PCA cable is bad.
The lower PCA is bad.
The upper PCA is bad.
Recommended Action:
Intermittent connections can be difficult to locate. If the Error 42 condition is intermittent, a connection issue is probably the cause. This is definitely true if the Error 42 occurred while the lift was within its normal physical range. Inspect the lift potentiometer connector and repair connection if necessary. If the intermittent connection cannot be found or corrected, replace the lift motor. A lift calibration number of 0 or 255 indicates an open or shorted potentiometer connection. This means the problem could be anywhere between the lift motor and the upper PCA. Typically it can be identified and tracked using an ohmmeter.
Using the appropriate service manual for the unit being tested, refer to the lift calibration procedure. If the information in the service manual doesn't match the lift position/physical lift position of the unit, recalibrate the lift motor. [Something caused the lift motor to be out of calibration. Investigate for cause and correct. Simply recalibrating the lift motor will not solve the problem.]
If the lift calibration number is not 0 or 255 and does not change when the lift motor turns, replace the lift motor.
Check continuity of the interconnect cable or swap with a known good interconnect cable to verify if cable is bad.
Swap the lower PCA with a known good lower PCA to verify if the lower PCA is bad.
Swap the upper PCA with a know good upper PCA to verify if the upper PCA is bad.
Error Code: 42
Model: All Models
Error Description:
Possible Reason:
Recommended Action:
Error Code: 42
Model: All Models
Error Description:
Possible Reason:
Recommended Action:
Unfortunalty when you get a JVM 102 error JVM Error 102 means There is an issue with one or more of the .cod files installed on the BlackBerry smartphone. During the boot up cycle, the .cod files on the BlackBerry smartphone were checked for modifications and problems were determined to affect one or more files
If you received a (Code 10) error and have more than one USB device
inserted, remove the devices and insert the Kingston DataTraveler by
itself. This error may be an indication that your particular system
cannot support more than one USB device at a time.
Is this COD??
If so back up your gamesaves from COD to a meme stick.
Then put COD in and see what happens.
If it works then the game save was corrupt.
And yes you will have to start again.
