Question about Dell Computers & Internet
Dell inspiron 530 error 3700:011B - Dell Computers & Internet
  • Official Brand Answer
  • 560 Answers
Christine Dunne,
The error represents a failed system fan. You will need to replace the fan in order for the error to go away. You can order the fan through the Dell Spare Parts Department at 1-877-717-3355.The fan part number for the mini tower is X755M. The fan size is 92x25MM.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Posted on Jun 01, 2015
    Brigadier General:
  • Dell Master
  • 3,400 Answers
Posted on May 11, 2015
SOURCE:
  • 68 Answers
SOURCE: Dell Inspiron 530 randomly shuts down and restarts
Sounds like it could be a virus. Or, a heat buildup problem - are all fans inside machine working? Is the fan inside the power supply operating? Was there any work done inside the computer recently?
If the hdw is all ok, go out and buy yourself a copy of Norton Internet Security 2009 - 1 user lic - $49.99 @ Staples. Do *not* buy any earlier vers. of this software! Install, update it, run computer computer scan - probably will find/remove some/many viruses.
If this helps, please take the time to rate my response to you.
Thanks and good luck.
gurutim
Posted on Mar 22, 2009
  • 61 Answers
SOURCE: Old speakers will not work with new Dell Inspiron 530
Speakers are pretty much universal. Plug them in, and connect the audio cable to the green receptacle on the computer.
Posted on Apr 05, 2009
  • 2418 Answers
SOURCE: I have a Dell Inspiron 530 0X0000007E error code
You can replace the Main board but how is the cost compaired to a newer machine? You can repl the main board with out much if any hassel to your windows install. If you repl w/ a different manufacture main board you will have to re-reg with windows.
Posted on Oct 17, 2009
RonPark
  • 855 Answers
SOURCE: Green LED on Dell Inspiron Desktop 530 - all OK?
Yes, on most desk top the green light in the back tells you that you have power to the cpu. Even though the unit is off it is telling you that the current supply is still there. This is a good feature if you move your unit as soon as you plug it in you know if the outlet is on or not.
SOURCE: Dell Inspiron 530 not recognizing HL-DT-ST-DVD+-RW
I'd try rolling back to the previous driver, maybe your machine isn't compatible with the latest driver ...
Posted on Nov 04, 2009
Where is the wireless switch on my dell inspiron 530?
The Inspiron 530 does not even come with wireless. So there is no switch for it.
Feb 17, 2012 | Dell Inspiron 530 Desktop Computer
Dell inspiron 530 cmos checksum
This error usually occurs when the CMOS/BIOS battery is flat.
Replace the BIOS battery and then boot up and go into the BIOS setting to setup the Date & Time etc.
Jan 30, 2012 | Dell Inspiron 530 Desktop Computer
Cannot Print from Dell 530 Inspiron w/Home Vista
Try this:
http://www.fixya.com/support/r3680773-completely_remove_printer_drivers
May 16, 2010 | Dell Inspiron 530s Desktop Computer
Dell Inspiron 530 not recognizing HL-DT-ST-DVD+-RW GSA-H73N ATA. Downloaded latest driver. No luck. Code 10 error.
Nov 04, 2009 | Dell Inspiron 530 -Intel® Pentium®...
That error message is usually coupled with removing an adapter connected to a RAID device. Have you disconnected anything in your computer recently? Have you opened it and cleaned it recently? If you've opened it to clean it, there's a chance that something may have come loose. If you know what you're doing on the inside of a computer, you can go through and make sure that everything is properly connected and then try booting again too see if that works.
Oct 17, 2009 | Dell Inspiron 530 Desktop Computer
Solid Amber light when starting the Inspiron 530 . Every time i start the Dell inspiron 530, the solid amber light comes on and it dont start. As per Dell user manual i have tried everything but of no use....
Amber led simplifies a start-up-error. This could be a number of things.
For example:
Check if HDD is connected properly
Check if RAM is connected properly / also if this is damaged your pc wont start.
Check your m/board for any loose capacitors an if they are not popped at the top.
Your LCD screen is properly plugged in to the m/board and if the cables aren't damaged they are very thin and fragile.
also could be the power supply...
Goodluck
Ryno Gerber
Jul 30, 2009 | Dell Inspiron 530 Desktop Computer
No dial tone on xp
U need to double confirm the phone line whether got dial tone or not. What u can do is to plug the phone line to a single line phone. If dial tone is available, u can able to make call.
Feb 13, 2009 | Dell Inspiron 530 Desktop Computer
Getting a manual
Use this link download varies manual concerning to system
http://searchapj.dell.com/results.aspx?s=dhs&c=in&l=en&cs=indhs1&k=Dell+530+Inspiron+manual&cat=all
the above will give below information on the site
Appendix: Dell Inspiron 530 Owner's Manual ... Appendix Dell Inspiron 530 Owner's Manual Specifications ...Cleaning Your Computer Dell Technical Support Policy (U... Product name: Dell Inspiron 530 Model number: ... Setting Up and Using Your Computer: Dell Inspiron 530 Owner's Manua... ...Using Your Computer Dell Inspiron 530 Owner's Manual Front View of the Computer...your computer when you access the Dell Support website or call technical...specifications indicated in this Owner's Manual reflects the maximum ambient operating... Glossary: Dell Inspiron 530 Owner's Manual ... Glossary Dell Inspiron 530 Owner's Manual Terms in this Glossary...code located on a sticker on your Dell computer. Use the Express Service Code when contacting Dell for assistance. Express Service...
May 25, 2008 | Computers & Internet
Open Questions:
Computers & Internet Logo
147 people viewed this question
Ekse
Clive
Clive
