Sewing names that run together
The space is most likely created with some straight stitching in the memory. At least, I believe that's how it is done on my 440.
Perhaps these tutorials will be of assistance:
9 21 BERNINA 830 sewing machine video instructions Combination mode
BERNINA 830 the best BERNINA of all time BERNINA
SOURCE: i need a bernina sewing machine manual
Sewing Educational Warehouse provided a very similar manual. Thanks for trying
SOURCE: bernina 830 old style need replacment part -under extention table
The clamping yokes for Bernina sewing tables for models 830 and earlier models were hand fitted parts. Welding this may change the geometry so that the table may not fit at all. Additionally the material is diecast AL, not cast iron, and may or may not accept TIG welding applications.
SOURCE: need bernina sewing machine model 730 manual
Here is a download - http://www.berninausa.com/webautor-data/486/BERNINA_730_731_732_manual.pdf
SOURCE: bernina 800d sewing machine
If it is a Bernina 800DL overlocker, the user manual is available for download at the bernina.com web site. Select "Support" and scroll down to Search Support Info for Bernina models. Once you download, you can enlarge the pictures on your computer screen as sometimes the photos are difficult to see in the book. Be sure to thread in the order as instructed. Guaranteed, your machine will not work if you do not thread in the proper order.
1. UPPER LOOPER FIRST
2. LOWER LOOPER SECOND, and the THREAD TAIL MUST CROSS OVER THE UPPER LOOPER AT THE LAST STEP.
3. Then thread the needles.
If any of threads are not fully seated in the tension disks, you will have issues.
