Question about Yardworks Broadcast Spreader Walk Behind
I need a replacement controi wire - Yardworks Broadcast Spreader Walk Behind
Need to remove fuse box to get to wire harness underneath
go to the wreckers and get a replacement fuse holder and wiring harness quicker and easier than trying to replace the fuse holder of the damaged wires
Dec 14, 2017 | 2007 Chevrolet Silverado 1500 2WD
Tip
How to Unlock Your Apex TV When Screen is Locked
If you find that your Apex TV is showing a blank screen with a red key on the bottom left then the Screen Lock otherwise known as Child Lock or Parental Control has been accidentally activated and your TV will not respond to commands from the remote control.
To resolve this and reactivate the TV simply press the (function or F) button and hold down the mute button on the remote at the same time for around 10 seconds. This will unlock the screen and allow you to view the channel as desired.
If your TV asks for a 4-digit code or password please enter 3308 or 6688 to unlock the screen or to reset any preset rating levels.
This extract is taken from an Apex Manual specific to the child lock function;
The Childlock function is designed to prevent chiIdren from watching TV. To activate: HoId down the F button and then press the MUTE button until the symboI “ ” appears on the screen. The TV will enter the Childlock mode.
Except for the “ ” symbol the screen becomes blue or black . To unlock the TV hoId down the F button and then press the MUTE button again.
Please Note:
The Childlock can be set or cancelIed only by the remote controI. After setting Childlock, secure the remote control in a safe place.
If this Tip has helped please do take time to indicate this by using the rating buttons on the page below.
Many thanks for using FixYa.
on Dec 17, 2009 | Televison & Video
Maytag Dryer MDE3706AYW has a burnt black wire, did the wire just have a bad day or do I need to replace the heating element and the wire?
All should be good. I think the element had run on due to a bad hi-limit thermostat that you said you replaced.
Oct 17, 2012 | Maytag MDE3706 Electric Dryer
Alternator on montero melted the wire and almost welded itself to the alternator i need to re wire the alternator and need to know what all wires i need to check and replace i need this fixed asap for it...
WHAT COLOR WIRES MELT TO ALTERNATOR ONE WHITE WIRE BATTERY FEED FUSE LINK WIRE OR THE WHITE AND BLUE WIRE TO VOLTAGE REGULATOR TO COMBINATION METER. WHEN YOU REPLACE ELECTRICAL WIRES BESURE TO PUT FLEXIBLE CONDUIT AROUND WIRES TO KEEP ENGINE HEAT AWAY FROM WIRES AND CONDUIT WILL KEEP WIRES FROM RUBBING CAUSING SHORT TO GROUND.
Jul 27, 2011 | 1999 Mitsubishi Montero Sport
1996 mazda b2300 manual blowing # 24 fuse, the ignition,clutch,starter fuse every time i turn truck over. Giggle the wires under clutch peddle replace fuse and it starts right up..why fuse keep blowing?...
They may not need to be replaced but they need to be repaired. Somewhere under there in that wire harness you have a power wire that has a bare spot chafed in the insulation. You'll have to unwrap that bundle, the one you jiggle, and check each wire carefully for a bare spot. Start with any wire that is red,pink, orange; those are the normal power wire colors, but don't stop if you find one. There could be more than one. Just tape over the bare spots, you don't necessarily need to replace them. If the wire harness has beeen rubbing on a piece of the car try to reposition it so this doesn't happen again. Zip ties work good for this. Hope this helps.
Aug 11, 2009 | Mazda B-Series Truck Cars & Trucks
About computer speakers
1 st check u r speakers ..........are they o k or not..
i think ur speakers r shot or not working......
to check u r speakers u can use any other audio source like a walkman,other computer. etc....
if u find that ur speakers are ok them u should check u r volume controle on ur computer man.............is u r volume is mute...
if u problem still reman then follow these steps..
1.check u r all cable connection ....they should be properly attached
2.go to u r computrs controie panal..
3.select sound & audio device..
4.check  u r all audio driver r working properly or not....
5.if volume is mute...get off the mute..
i m 100% sure u r problem will be solved man..
dont forget to tell me u r problem solved or not
best regards & best of luck..
Oct 25, 2007 | Audio Players & Recorders
Resetting the parental control password?
try master pass 3308 Childlock The CHlLDLOCK function prevents chiIdren from watching TV. HoId down the F button and then press the MUTE button until the symboI ? ? appears on the screen, and the TV enters the CHlLDLOCK mode. Except for the symboI? ?, the screen becomes blue back and mutes when you press the buton to turn the TV off, then turn the TV on after setting the CHILDLOCK function. To unlock the TV, hoId down the F button and then press the MUTE button again. Note: The CHlLDLOCK can be set or cancelIed only by the remote controI. After setting CHlLDLOCK, secure the remote control in a safe place
Aug 14, 2007 | Apex Digital AT1314DV 13 in. TV/DVD Combo
Yardworks Broadcast Spreader Walk Behind Logo
327 people viewed this question
Top Yardworks Garden Experts
roeb
john h
Marvin
Marvin
Are you a Yardworks Garden Expert? Answer questions, earn points and help others
