Dear sir,i purcahsed d90 cam but result is not good wat can i do ? wat can do setings get good result
The d90 takes excellent pics, but you need to understand the settings. White balance determines the accuracy of the color by setting what the camera sees as whit compared to what you do. Then you need to set the ISO, which is how sensitive it is to light. The higher the number, the more sensitive. In super bright situations you may need to go as low as 200, 800 in lowlight. 400 is a good average, 100 is rarely used. then your aperature value (a/f) this determines how much light the camera actually lets in, not to be confused with the sensitivity (ISO) which is specifically how sensitive the film is (not that you have any). Then is the shutter speed, which is how long the camera exposes the film when you hit the button-for fast moving objects, you want the shutter to open and close really fast so it doesn't blur;if it stays open too long it will capture the object in motion-if someone is running and you have a slow speed, the image could be the runner taking three steps as opposed to a still picture. To start.your setting when you take a pic, look at how much light you have. For indoors with no lights on during the day or outside cloudy, ISO 400. In at night with bright lights or outside sunny day, ISO 800. Then determine the speed of your object. A good standard for slow objects is 1/20-1/60. Set that, then set your aperature (f value) so the picture looks at the right brightness. If you adjust the aperature all the way and still need more or less light, adjust the shutter. Then cycle through your white balance options to make sure your color looks right and take a picture. If it comes out really grainy, your light settings were not right, you should pay attention to your ISO and aperature settings.
