Check for voltage at the headlight connectors with the light switch turned on. If there is voltage but your lights do not illuminate, your bulbs are burned out. If there is no voltage, verify that there is supply voltage at the output of the light switch when lights are turned on. No output voltage, first check continuity between the switch and the lights, then check for voltage at the switch input. If there is input voltage but no output voltage, replace the switch. If there is no input voltage, check the wiring between the fuse panel and the switch.
SOURCE: no current to right headlight 1994 VW Jetta. Are
There are seperate fuses for the right and left lights. The fusebox should be under the dash, on the driver side.
Testimonial: "THANKS FOR THE INFO"
