Lid closes to push down lever to let machine spin how do i fix that mechanisum ?
  • Washing Mach... Master
  • 5,420 Answers
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
lid closes to push down lever to let machine spin  - 25684036-k4ataymuwmgrdb2rqqdy5pxt-4-0.jpg
25684036-k4ataymuwmgrdb2rqqdy5pxt-4-2.jpg lid closes to push down lever to let machine spin - 25684036-k4ataymuwmgrdb2rqqdy5pxt-4-9.jpgt/uploads/images/25684036-k4ataymuwmgrdb2rqqdy5pxt-4-9.jpg" alt="25684036-k4ataymuwmgrdb2rqqdy5pxt-4-9.jpg" class="h_mi" />
Posted on May 08, 2015
SOURCE:
WONT SPIN ?
There is a switch..(interlock) that activates when the lid is open or closed...not allowing the unit to go into spin if the lid is open. It may be that the machine thinks the lid is open. The switch could be dirty or broken or loose. There is a little leg sticking out from the underside of the lid, that goes into a slot on the machine when the lid is closed, that activates the switch. Make sure this all looks good, (no obstructions or debris in the slot) and the leg goes all the way into the slot (lid closes all the way).
You should see a little plastic lever in the slot that the leg on the lid will contact when you close it. If it is there and unobstructed, try gently pushing down on with your finger or the back of a pencil or something, until you hear a faint click (switch). It should spring back into position when you release. Its a quick and easy check. Good luck.
Feb 25, 2016 | Washing Machines
Does not drain and go into spin cycle. Checked outlet for 110v power supply, and good. Also ran an extension cord from laundry room into an interior outlet to double check and still to no evail.
most likely the lid switch is bad, listen for a click when closing the lid, try pushing down on the lid, if it works replace the lid switch, if you hear no click try a pen or screwdriver etc to push down the switch lever.
Feb 11, 2010 | Kenmore Washing Machines
Won't spin and drain
check the switch for the lid. the machine will not spin or drain if it thinks the lid is open. use a screwdriver or ink pen to push on the little lever. the lid has a small stick of some sort sticking out. the lever is in the hole that the stick normally goes into. the lever should click each time. if not, replace it. good luck
Nov 15, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore Top Loading 204329 will fill and agitate but willnot drain or spin unless I put a screwdriver in the area where the plastic thingy on the lid normally goes..what do I need to do to fix this?
The lid switch acts as a safety to prevent injury when the tub is spinning at a high speed. Pressing the switch down with a screwdriver when the lid is open bypasses that safety function. Close the lid (with the machine not running) and listen to hear if the switch is clicking when the plastic rod contacts it. If it does not click then the rod is not pushing it down far enough. Adjust the lever on the switch by bending it up slightly until the plastic makes contact. If the plastic rod is broken or missing, replace it.
Oct 20, 2009 | Kenmore 24032\24036 Top Load Washer
Will not spin clothing out
do you hear it click when closing the lid ? Sometimes , the lid switch arm , will work inserting something into it , but not with the lid closed . Try checking it using the lid itself . sometimes , the arm wears to where it has to be pushed farther down to work so the actuator on the lid cannot push it far enough down . Have to replace the lid switch for it to work properly or bypass the lid switch from under the console .
Aug 19, 2009 | Washing Machines
Kenmore Elite 24952 topload washer stops after rinse before drain
sounds like lid switch ..if switch is along right side of of opening try holding it down with pencil or other slinder object if spins ok replace switch if switch is not visible it may be under left rear hinge area ck hinge screws and tighten or try pushing hinge lever toward back slightly
Nov 26, 2008 | Kenmore Washing Machines
No spin
lid switch sounds like some ge had a plunger type switch operation ck for broken pin on lid that pushes switch lever down ..others had a magnetic type switch magnet on lid front right corner that closed switch on cabinet front corner
Jul 31, 2008 | GE WBSR3140DW Top Load Washer
Won't drain or spin
Open and close lid, listen for 'clicking' sound. If no 'clicking' sound, this indicates a lid switch problem.
The lid switch on your machine, based upon the model number you provided, is hidden under the right side of the cabinet and is activated by the right lid hinge.
The first thing to check are the screws on the right lid hinge, if they come loose, (as they usually do) the switch will not activate properly. If this does not resolve the issue, proceed as follows:
1. Lift the console. Look in the back of the console, in each corner there will be a screw, unscrew until the console can be pushed forward.
2. You will find a lid switch connector (white in color). Unplug the switch from the connector.
3. There will be two brass colored clips. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver down and away from you and the clip will release.
4. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Tilt and slide cabinet forward to remove.
Inspect the switch for proper operation by moving the lever. Also check the lid hinge lever to insure proper pressure to the switch, bend if necessary.
If you need further assistance, let me know
Regards;
reg501
Jun 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
WASHER FILLS BUT THEN WON'T START. WILL LIFT THE LIFT AND CLOSE SEVERAL TIMES AND THEN WILL START. NOW DOESN'T START AT ALL. IS THIS THE SWITCH ON THE DOOR, SHOWING IT ISN'T CLOSED SO IT WON'T START?
must be a whirpool or kenmore shut lid try pressing down on left rear corner be sure lid hinge screws are tight then raise lid on left corner under top out of sight you will feel small lever push toward back of washer slightly and then try again also if lid center has popped down push up slightly in center till lid pops back up sen it happen once where washer would not spin
Jun 17, 2008 | Washing Machines
Washer won't complete spin cycle
Try pushing down lightly on the lid and see if the spin cycle starts back up. On mine, the same thing happened because the small plastic pin attached to the lid was just barely long enough to push the switch that tells the washer that the lid is closed. The spin cycle will only run when that switch is pushed, i.e., when the washer thinks the lid is closed.
Jan 06, 2018 | Maytag Neptune MAH6700A Front Load Washer
Washing Machines Logo
63 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
