Hello George;
My name is Peter. I am a retired field service refrigeration technician.
The error code is either a bad freezer fan, which is more likely, or a bad control board.
Motor Part Substitution: 4681JB1027C Cost: $55.00
Part #: EBR41956418 Cost: $125.00
There is a reset button on the board located in the back of your unit. GROUND YOURSELF BY TOUCHING SOMETHING THAT IS BARE METAL. STATIC ELECTRICITY WILL KNOCK OUT A CONTROL BOARD. Push the reset button only once. Open the refrigerator door while holding the light switch button in. Hear the fan?
Go into the following website, put in your model number and select parts. Parts and diagrams will appear.
Water Filters Lawn Garden Appliance Parts
You can purchase the parts for allot less over the internet.
If you call a service company, they will double the cost of the part and probably charge you $250.00 or more for labor. The labor cost for a bottom freezer is allot higher than a side x side or top freezer because of the difficulty to access the freezer components.
Bottom freezers and units with the ice maker or ice bucket on the door are the worst.
On my daily service calls, 65% were for either Samsung or LG.
Next time stay away from these and the above.
Causes of the Er rF Error Code
An Er rF error code, as we've mentioned, indicates that there's some kind of problem with the fridge's fan motor; specifically, that the fan motor isn't running when it should be.
Dec 16, 2021
Kenmore Refrigerator Error Code = Er 1F
Error Condition = The fan for the ice compartment failed
Repair or Check = Icing fan blocked - ice fan motor is defective - wiring in the circuit is defective - control board has failed
Parts Needed = Ice fan motor - Wiring harness - Power control board Kenmore Refrigerator Error Code = Er IF
Hi, here are the error codes and meanings for your Refrigerator
Error Code, All Error Codes will have an ER on the left side, followed by the error on the right: Er IF - Icemaker Fan Error - This can be caused by frostaccumulation on or around the icemaker fan. Unplug the unit for 3-4hours to allow this to melt off. If error code persists, call CustomerService. Er FF - Freezer Fan Error - This can be caused by frost accumulationon or around the freezer fan. Unplug the unit for 3-4 hours to allowthis to melt off. If error code persists, call Customer Service. For remaining error codes, try unplugging the unit for a couple ofminutes to reset the unit. If the error code persists, call CustomerService Er FS - Freezer Sensor Error Er rS - Refrigerator Sensor Error Er ds - Defrost Sensor Error Er dH - Defrost Heater Error Er CF - Cooling Motor Error Er CO - Communications Error
If the control does not see a signal coming back from the fan motor you will get this error code. Please see the image below from the service manual that explains the ER IF error code.
Error Code Er FF This code is not to be confused with the O FF or demo mode error message. The "Er FF" error code indicates a problem with the unit's freezer fan. The freezer fan controls the temperature in the freezer. The source of this error is most likely ice buildup. As with the Er IF error, allowing the unit to thaw should resolve the issue. Contact customer service if the error code continues to be displayed after having thawed the unit.
This is an error code for the icemaker fan motor. If the control does not see a signal coming back from the fan motor you will get this error code. Please see the image below from the service manual that explains the ER IF error code.
