It does not appear to be screwed into it's recess but it will not budge when trying to slide it out.
Get an installer manual
Testimonial: "Everyone knows that it's almost impossible to find any manuals for my ovem - so answer is not very helpful."
Part No. Photo Description Price Inc VAT
H001486 TOP OVEN THERMOSTAT £38.21
H017571 TIMER RED DISPLAY £100.79
H001663 TOUCHSTRIP BLACK £4.74
H005780 ELEMENT TRAY £6.08
H005773 BOTTOM TRAY £20.39
H005755 INTERMEDIATE TRAY £25.19
H006184 OUTER TRIM £23.99
H001421 GRILL PAN TRIVET LARGE £13.37
H001218 WASHER BROWN £6.17
H001762 TERMINAL BLOCK £9.59
H001634 TIMER BRACKET £6.17
H011632 BUFFER £6.17
H010132 LID SPACER £4.74
H001380 FRONT GUIDE BUSH £4.74
H001381 REAR GUIDE BUSH £4.74
H001523 CAVITY SUPPORT BUSH £4.74
H001625 TIMER BUTTON BLACK £5.39
H001648 WIRE MAINS LEAD £16.79
H010074 PHIAL CLIP £4.74
H008556 ANTI RATTLE CLIPS £4.74
H007996 SHELF RUNNER CAVITY CLIP £4.79
H006354 GRILL HEATSHIELD £32.45
H006305 FAN COVER ENAMEL FINISH £27.59
H013422 SERVICE PANEL TOP COVER £23.99
H013612 DUAL GRILL ELEMENT 280W KIT £62.39
H012862 BOTTOM ELEMENT 1000W £26.87
H001489 FAN OVEN ELEMENT CIRCULAR 2500W £39.59
H011595 BLACK ENDCAP X2 £7.66
H000289 FACIA PANEL STAINLESS STEEL £83.99
H009934 DOOR FOOT INSERT NEW TYPE £5.99
H006299 FRAME FRONT £40.79
H000282 FACIA ASSY £45.59
H013423 M/OVEN DOOR ST/ST SELECT 600 £151.19
H001352 OVEN INNER DOOR GLASS MK1-2 LINED £131.99
H018594 OVEN INNER DOOR GLASS MK3 LINED 495MM X 393MM £68.39
H012418 GRILL PAN LARGE £40.88
H010040 GROMMET £6.17
H001620 HEAT DEFLECTOR GUIDE £4.74
H008097 OVEN SHELF GUIDE £16.19
H015304 OVEN SHELF GUIDE 15 POSITION £9.59
H001957 INSTRUCTION MANUAL £3.60
H000057 GRILL PAN HANDLE INC GRIP £32.39
H001200 GRILLPAN HANDLE COVER BOTTOM £13.37
H008076 GRILLPAN HANDLE COVER TOP £11.99
H006195 HANDLE SILVER £38.39
H001561 WIRING HARNESS SELECT 620 £11.99
H006512 HEATSHIELD £14.39
H011470 HINGE BAR BLACK FINISH BEFORE JAN 2002 £15.59
H001427 PHIAL HOLDER 70MM £6.38
H001579 INDICATOR DISC £74.39
H001580 INDICATOR DISC £11.99
H009758 INSULATION £98.39
H001902 CONTROL KNOB £9.59
H018630 OVEN LAMP ASSY INC BULB £47.99
H001530 NEON INDICATOR £9.59
H005745 SIDE FRAME L/H £20.39
H005744 SIDE FRAME R/H £20.39
H006391 E/C OVEN CAVITY ASSY £227.99
H005760 INNER CONTROL PANEL £4.74
H005775 REAR SERVICE PANEL £29.99
H041765 FAN OVEN MOTOR £59.99
H001472 OVEN DOOR HINGE PIN 16MM £4.74
H001515 COMPRESSION SPRING RETAINER £4.74
H017387 OVEN & GRILL DOOR SEAL £45.59
H001354 O RING SEAL 4MM £4.74
H019876 SHELF MAIN OVEN 452 WIDE £33.59
H001470 TENSION SPRING £4.74
H001452 DOOR TENSION SPRING £5.39
H001598 OVEN DOORSTOP £5.86
H011582 MAIN OVEN KEY £4.74
H010006 CAVITY SUPPORT £5.86
H001587 SELECTOR SWITCH £19.08
H001402 THERMAL CUT OUT SWITCH 150C
buy the manual from the manufacturerhttp://www.hygenadiplomatspares.co.uk/cg...
