Cell Phones Logo
Tayden Foulger Posted on May 06, 2015
My sms dongle says it's charging or charched.. but wont turn on after I unplug it from the charger
Bert Irvine
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on May 06, 2015
Bert Irvine
Contributor
Level 1:
New Friend:
Answers
10
Questions
Helped
6822
Points
28
Replace the battery, or make certain the charger is charging. Does the dongle get excessively warm or hot
2 Related Answers
Anonymous
  • 7752 Answers
  • Posted on Dec 26, 2008
SOURCE: restart if it is charging
change the battery
Anonymous
  • Posted on Jun 06, 2009
SOURCE: phone wont charge
buy a new one.
3answers
What to do if my galaxy wont charge
At this level of charge their is not enough to start the boot process , if it doesn't charge at all their may be a fault with the Battery cell , however i had a similar issue, just leave it for a while, if their is still no indication that its charging or it wont turn on their could also be a problem with the Start Button
2answers
Samsung galaxy Y pink wont charge
i tHink iNnn yOur cEll pHone cHarging piNn iZzz dEstroyed !!....!! rEpair yOur cEll pHone tHen iTz wOrking !!....!!
My sms audio by 50 cent wireless dongle stopped working after putting it for charging
When I plug in my dongle to charge the blue led light comes on but when I want to use it, it won't turn on??
1helpful
2answers
Can I charch my new ryobi batery lithium whith the old charch
NO THE OLD CHARGER FOR THE BLUE ONE+ TOOLS WILL ONLY CHARGE NICD BATTERIES. HOWEVER THE INTELLIPORT DUAL CHEMISTRY CHARGER WILL CHARGE BOTH NICD AND LION BATTERIES. ALL BATTERIES ARE COMPATIBLE WITH ALL ONE+ TOOLS
Trouble charching battery, after 6 houres only one bar on battery . Charging will not complete.
1 charger
2.battery
3.charging port
There are three ares to look at,
There are three different things you can try to determine the real problem of your phone, firstly, try use a similar charger to charge the phone to see if it will hold charge, if it does, it means your charger is bad, get a new charger. secondly, another area you will need to look at is removing the battery on your phone and charging the battery of your phone with a similar phone to see if the phone will charge the battery and hold charge, if it did not, it means the battery of your phone is bad and will need to be replace, lastlt, check, the charging port of your phone might be malfunctioning and not charging your phone, if the two above look good, it means the charging port is the problem, replace the charging port and you will see that your phone will hold charge.
Take care.
Mp3 player wont charge or turn on
i have the vl 868 and it would only turn on with the charger in- not when it was unplugged. it took me awhile- you have to turn the switch on and then hold play for like 4-5 seconds for it to turn on.
My mp-c7085
THE INTERNAL BATTERY NEEDS TO BE REPLACED OR THERE IS A BROKEN WIRE
How clear the not charching for 1100?
charge it with another charger or it may be due to the damaged battery so try to check it with another battery
Jul 12, 2008 • Nokia 1100
My Creative Zen V
usually it takes about 6hrs for it to fully charge, if it still does not work after this, check to see if it is in lock mode. hope this helps :)
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
