I dropped my sgh-d807 in water,the screens blank and wont turn on
I dropped my sgh-d807 in water. The screen went blank so i started trying to try it with a tissue. The battery was also wet. After 3 hours i dried it with a hair drier and now it won't even turn on!!
u broke your phone becus i did the same thing and had to buy a new phone sorry that happenedu broke your phone becus i did the same thing and had to buy a new phone sorry that happened
You can't post conmments that contain an email address.
It should be fine to call when the phone is charging. It could be that the phone was "sleeping" as it charged and then the sudden energy draw of the phone call while it was charging screwed up the battery. I think you should take it to the shop.
D807 Unlock Samsung SGH-D807 SOLUTION for those that need this code. It's a lot cheaper than 29.00 from some of these websites....
-------------------------------------------------------------------------------- 1. If you have changed your phone password, change your password back to the default 8 zeros (00000000). 1a. NOTE (Modification here by my experience): Goto SETTINGS, SECURITY, then SIM LOCK and disable this before proceeding. 2. Put a SIM card that is from a network other than the one your phone is locked to (I used a TMOBILE card from my buddy Darin) 3. When Incorrect SIM (I got invalid card and there was a sim card graphic spinning) error comes up, type *#9998*3323#. 4. White screen will appear with an exit option. Press the right softkey. (I ended up pushing the down key to get a menu) 5. From the menu that appears, select the Malloc Fail option. This will reboot the phone and the normal service screens will appear. 6. Type *0141# and then press the green call key. "Personalization" or "Personalized" will appear. 7. Turn off your phone and put the original SIM back in. 8. Turn on your phone. You will receive a prompt to enter a password. 9. Type 8 zeros (00000000) (This is because the SIM LOCK Mentioned earlier gets switched back on) 10. Completed. You have now unlocked your phone.
Easy as pie. Now you have an UNLOCKED Samsung D807 =) worked on my brand new 2 day old Samsung D807 phone.
Oh also guys I called Cingular (on hold for 1 hour with these losers) and they told me there is no way to SAVE phonebook contacts from the phone to your sim card. Now this really pisses me off. So I did some searching and found out that with the studio software from samsung you are able to edit and move contacts from your phone to the sim and back. Or copy from the phone and put them on the sim card. Just thought you all should know as there is no menu option on the phone only you will need a data cable..
remove the battery for few minute if it still dont work look in the manuel how to reset normally they put it in the back small push it with a pen hope it work cheers
Call the service provider for a firmware update if your able to get it past the logo screen. I went thru 3phones and 2 had the problem.. I just hit the back top of the phone on the ground it went fine :-)
u r phone is shortby water at first cleen it by ipa cleener dont use petrol& water than u have to flash it flash mcu and ppm if problem will still ther than give heat treetment to flash ic and cpu cleen all pins(cunector) chack battery voltage it should be min 3.7volt than put it in to phone properly and switch it on it wii on 100%
