Hi was wondering if some one could help having same problem with my quinny buzz. But the button with the arrows has come out can it be put back in or is it broke. Please please help.
Hi - Please visit the Quinny International website and use the Contact Us tab for your enquiry to be sent to the local Quinny customer care team who can help you - Quinny urban strollers and buggies
SOURCE: Problem with unfolding of Quinny Buzz
Hello jenum71:
Sometimes the stroller does not automatically unfold easily if the seat is attached. If the seat is not attached, and the stroller is still not automatically unfolding properly, there is probably something wrong with the internal spring. have you had the stroller long? Quinny says that the spring will last "virtually forever", but we all know that there are always lemons. If you have not had the stroller for a very long time, contact quinny and ask for a replacement. They have been pretty good about getting them out to clients.
If you have any further questions, feel free to contact me anytime: [email protected]
StrollerInfo
www.StrollerInfo.com
SOURCE: Folding - Quinny buzz 3
HI, if it's the same model as I have: start with the frame facing you with the break on, you will see 2 long grey 'buttons' situated where the seat clips in to the frame. One of these buttons has arrows on it like this ^, this one you push in the direction of the arrows. The other you, simultaneously push in. You then push the whole frame down - this takes a bit of pressure. The whole thing should fold flat, you then secure it with the cable located near the wheel.
This sounds very complicated, it isn't once you've done it the first time - I hope it makes sense to you!
SOURCE: where can i get my quinny buzz pushchair repaired?
Try contacting Quinny directly through their parent company www.dorel.co.uk The website has phone numbers and an email contact
SOURCE: folding and unfolding stroller/ how to adjust stroller seat?
if you place your hands on either side of the stroller keeping your hands on the side of the handle at the same time pull uo and that rfolds and unfolds stroller
SOURCE: Problem in folding quinny buzz to stiff
I would suggest that when folding the Buzz, stand in front of it first. Push down one of the grey buttons, then slide and push the other, then you can use your whole body weight to push the pram to the floor enabling you to collapse it. It is also easier if you remove the seat prior to folding.
I hope this helps.
If you're
in the UK
and the product is under 2 years old, please contact your retailer with your
proof of purchase and they can arrange for it to be sent to our engineers for
inspection / repair work required under warranty.
If you're in the UK and the product is over 2 years old or you no longer have
proof of purchase please contact the customer care team on 01284 413 141
Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays) to discuss booking
it in for chargeable inspection / repair work required.
If you're outside the UK please visit www.quinny.com and select the country you're in, then use the "Contact Us" tab on the right side for your enquiry to be sent through to the customer care team in your country.
