Have Samsung front loader. Tried to start load of laundry. Shut door pressed start button led light up beeped several times then shut off. Nothing on display at all and door is locked. Checked power.
I would check that the front is secure. My old front end loader would kinda do the same thing. If I didnt have the door exactly shut it wouldn't start. Start there hope it helps
Hi, Welcome, Your temperature is to high and running wild . So the system has shut it down for safety reasons. You need to call service for a diagnoses if you do get it running, do not leave it unattended or better yet do not use it as is!
Send me the model number and I can send you the schematics!
Thank You for trusting us with your questions. Huum Please remember to leave a solved rating before you sign off!
If that machine was so easily damaged (the electronics in particular) it is a sorry design.
About the only thing I would suggest is to actually pull the AC plug and ignore it over night.
Whatever safety 'feature' caused the door to lock, may reset itself if given enough time.
And yes, Sears service is not as wonderful as they claim.
Press "end of cycle". Plug off the wall. Code can be an indication of several issues. The most common cause is over-sudsing in the machine. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire, see that all wires are tightened..........
Try the above..........
ok try first to make sure the detergent drawer is closed tight if its not will stop washer is the door locked some times you have to close them firmly make sure the lock light is on hit pause cancel twice then try washer
un plug your machine for an hour if you can open the door open it and then put the machine plug back in with the door open keep it open till the machine comes on then put the program to what you want and then shut the door it then should be ok its called a reset try it hope this solves your problem
