Washing Machines Logo
Alisha Despain Posted on May 04, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How much is the inlet valve cost - Washing Machines
Level 3:
  • Washing Mach... Master 17,130 Answers
  • Posted on May 04, 2015
Level 3:
Answers
17130
Questions
0
Helped
3634652
Points
52372
Normal cost of the inlet valve will vary between $20 to $35, since you have not specified the model. Check if the filter is clogged and replace only if the coil is open,. if not you can tap and clean with back flushing.
Model sgs46m78au. Why isn't it filling?
Most common is a burnt out inlet valve. Turn off water and disconnect power. The valve on Bosch dishwashers is at the back on the bottom panel. The water feed pipe is attached directly to the inlet valve. The valve itself iis set into a small rectangular panel that is sometimes just clipped in or held with two screws at one end. Remove this panel and disconnect the two wires on the valve and disconnect the internal feed pipe. These valves are common on Neff, Siemens and Bosch dishwashers and washing machines and generic after-market replacements can be had for less than £10 (about £25 from Bosch). If it is not a defective inlet valve it could be a defective control board in which case the the cost of replacement has to be weighed against the cost of a new machine.
tip
How to service water valves
If the washer won't fill or fills very slowly, if it overfills, or if the water is the wrong temperature, the water inlet valves could be faulty. These components are easy to locate and very easy to replace, at little cost. When you suspect an inlet valve is faulty, first check to make sure the water faucets are fully turned on and properly connected to the hot and cold inlets of the valves. Then check the screens in the valves; if they're clogged, clean or replace them. If water doesn't enter the tub, set the temperature control to the HOT setting. If there is no water, set the control to the WARM setting. If all that comes out is cold water, the hot-water inlet valve is faulty. Reverse the procedure to test the cold-water valve, setting the control first on COLD and then on WARM. If the tub overfills, unplug the washer. If water still flows into the tub, the valve is stuck open. In any of these cases, the valves should probably be replaced. To check the valve assembly:
- Remove the back service panel and disconnect the hot-water and cold-water hoses to the valves.
- Remove the hoses connected to the valves inside the cabinet. Also disconnect the wires from the terminals. Back out the screws holding the valves to the machine. The inlet valves have solenoids (a coil of wire that carries a current) inside the housing. These can be tested, but chances are the valves are simply worn out.
- Tap the solenoids with a screwdriver. If this doesn't work, replace the entire inlet valve assembly. Repairs usually cost more than a new part. Make sure the replacement valve assembly is exactly the same type as the old one. Install it in reverse order of the way you disconnected the old one.
on Jan 16, 2010 • Washing Machines
Water trickles in past inlet valve, doesn't fill dishwasher fast enough. Can i use a different inlet valve due to cost?
Hey Tommy, Your description leads me to think that you are plugged. I have never had to change a valve trying to change flow. I would not do that.
Take off the hose before the valve and be sure that you have good flow from the source. If so, see if you can remove and open up the valve. Some you can and some you cannot... If you cannot save it, get the correct replacement and it should work fine.
I think your valve is plugged. look for a screen that you can clean in the inlet of the inlet valve.
Doc
Bosch Nexxt 300 series WFMC2201UC has no water coming in. I have replaced the inlet valves, cleared all screens in hoses and still no water. It seems there is no power to the inlet valves. Is there a...
You can check the inlet valves with either an o'scope or a multimeter. Unfortunately, the control module PN: 661081 controls the voltage to the inlet valves and costs around $240.
Sorry, to give you the bad news.
Water in the door and ice maker has stopped working
Most probably, its faulty water fill inlet valve.But the possibilities for this problem are.The water main valve is turned to off.First check that.If its turned to on, then its not that case.The water passing line / tube is blocked or unplugged from the valve.First see, if its properly connected and not got loose, if that is not the case,m then check if its got friezed and ice got collected in that tube.If its clear, then its not the case.Then other possibility is water inlet valve.The water tube connects to the water inlet valve.If this inlet valve is faulty, then it will not let the water to enter in water section or icemaker section.The water inlet valve is not very costly part and easy to replace.Just connect proper tube to the valve, while replacing it.You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
1helpful
Why is there only hot water going in the washing machine?
the cold water valve is stuck shut inside washer.
Servicing Water Inlet ValvesIf the washer won't fill or fills very slowly, if it overfills, or if the water is the wrong temperature, the water inlet valves could be faulty. These components are easy to locate and very easy to replace, at little cost. When you suspect an inlet valve is faulty, first check to make sure the water faucets are fully turned on and properly connected to the hot and cold inlets of the valves. Then check the screens in the valves; if they're clogged, clean or replace them. If water doesn't enter the tub, set the temperature control to the HOT setting. If there is no water, set the control to the WARM setting. If all that comes out is cold water, the hot-water inlet valve is faulty. Reverse the procedure to test the cold-water valve, setting the control first on COLD and then on WARM. If the tub overfills, unplug the washer. If water still flows into the tub, the valve is stuck open. In any of these cases, the valves should probably be replaced. To check the valve assembly:
Step 1: Remove the back service panel and disconnect the hot-water and cold-water hoses to the valves.
Step 2: Remove the hoses connected to the valves inside the cabinet. Also disconnect the wires from the terminals. Back out the screws holding the valves to the machine. The inlet valves have solenoids (a coil of wire that carries a current) inside the housing. These can be tested, but chances are the valves are simply worn out.
Step 3: Tap the solenoids with a screwdriver handle. If this doesn't work, replace the entire inlet valve assembly. Repairs usually cost more than a new part. Make sure the replacement valve assembly is exactly the same type as the old one. Install it in reverse order of the way you disconnected the old one.
I have a ge washer wpsr3120w0aa that leaks water when rinsing
©2006 Publications International, Ltd.
If an inlet valve is faulty, check the water connection and the
valve screens. Try gently tapping the solenoids;
if this doesn't work, replace the inlet valve assembly.
Troubleshooting Water Leaks
Water leaks in a washer are often difficult to trace. There are many possibilities to look for. The problem could be a loose connection, a broken hose, a cracked component, or a defective seal. It could also be a hole in the tub. If a hole in the tub is the problem, it's usually best to replace the washer.
Most leaks can be eliminated by tightening water connections and replacing deteriorated components. To stop a leak:
Step 1: Check the lid seal. If faulty, replace with a new gasket.
Step 2: Check the hoses at faucet connections. Tighten connections or replace hoses.
Step 3: Check the hoses at water valve connections. Tighten connections or replace hoses.
Step 4: Check the drain hoses. Tighten connections or replace hoses.
Step 5: Check the inlet nozzles. Tighten connections or replace nozzles.
Step 6: Check the splash guard. Tighten connections or replace.
Step 7: Check any plastic valve. Tighten connections or replace.
Step 8: Check the outlet hose to drain. Tighten connections or replace hose.
Step 9: Check the water pump, using the procedures that follow.
5helpful
Water does not shut off. Water flows constantly
The cold water will not run.
GE WHRE5260E1CC NO HOT WATER
hi If the washer won't fill or fills very slowly, if it overfills, or if the water is the wrong temperature, the water inlet valves could be faulty. These components are easy to locate and very easy to replace, at little cost. When you suspect an inlet valve is faulty, first check to make sure the water faucets are fully turned on and properly connected to the hot and cold inlets of the valves. Then check the screens in the valves; if they're clogged, clean or replace them. If water doesn't enter the tub, set the temperature control to the HOT setting. If there is no water, set the control to the WARM setting. If all that comes out is cold water, the hot-water inlet valve is faulty. Reverse the procedure to test the cold-water valve, setting the control first on COLD and then on WARM. If the tub overfills, unplug the washer. If water still flows into the tub, the valve is stuck open. In any of these cases, the valves should probably be replaced. To check the valve assembly:
Top Washing Machines Experts
john h
