After the power has gone out and returned suddenly, the machine shows three LED lights flashing simultaneously on the far left side of lights, now the machine does not work. How do I fix this?
Press START/PAUSE and any one of the option buttons
simultaneously for at least two seconds: the LEDs first switch off,
and then display the flashing sequence corresponding to the
alarm condition.
Examples:
Alarm E43 (problems with the door safety interlock triac) will be displayed as follows:
• four flashes of the END OF CYCLE LED indicate the first digit E43;
• three flashes of the START/PAUSE LED indicate the second digit E43;
So, error code E55 as you specified does not exist. Any how, family error code 5 (first digit) means problem with motor. Error code could be E51,E52,E53 and E54.
Possible causes:
- faulty motor
- motor brushes (very often)
- faulty tachometer (integrated in the motor but is replaceable)
- faulty electronic (Motor power triac short-circuited or motor relay contacts sticking).
With the printer plugged in and powered off, press and hold the Resume/Cancel button, then press and hold the Power button. (DO NOT release the buttons. The LED light should be green to indicate that a function is selectable.).
While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.).
While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.).
When the LED light is green, press the Resume/Cancel button 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.).
Press the Power button. The LED lights in green, and the reset is performed. (When the operation completes, the printer returns to the menu selection mode automatically.).
Press the power button to exit service mode.
Note: if you accidentally press the Resume/Cancel button more than 4 times in step 4 then just press the Resume/Cancel button at least 10 times and the printer will be returned to step 4 automatically
If the 45 second reset will not work by holding in the power button the console for that amount of time then releasing, you may need to return the high priced piece of ****. I have gone through three of them so far and they all keep asking me to "please switch the control to the player 1 setting" and thats it. I think they mass produce these so fast that there cannot by any law of physics be any time left for QA to check them out before they leave the factory. The net is littered with problems on this.
to clear the 991 Takagi code, simultaneously press the bottom 2 grey buttons of the four just to the left of the flashing LED light. When the LED stops flashing, release and then press the reset button on the black panel about 8 inches above that
That is the drum replacement light reset it by pressing these keys: Clear, then the far left key, then Clear again then far left again.
So C, far left, C, far left
If done quickly like within 4 secomds the display should go blank. If so then key in 24 as if you were making 24 copies.
Now press the print button.
Now key in 7 and hit print again.
You should now be getting flashing zero's
Turn the machine off then on and the light should be gone and the copier is ready to use.
You can reset your drum life at least once with no problems.
In G5 always the cover should be closed properly if not it will start the fan very fast like a blower and the red leds will be on showing that the heat is over so please check that the cover is closed and locked from behind so itworks smooth and the power supply is standard or normal
u should always use genune parts with mac..
thanks
Power off printer and covers closed
Hold down the Resume button then press and hold POWER, the Green Indicator will
light. While holding down POWER , release RESUME
Double click (2 clicks) RESUME then release BOTH POWER and RESUME and wait
still the printer stops blinking.
When the indicator lights steady, press RESUME three(3) times. The indicator
should be ORANGE.
Press Power to set data
I got the solution from the Internet at the following link: http://www.fixyourownprinter.com/forums/inkjet/15620
