Troy Bilt 5.5hp Self Propelled Mower Logo
Scott Hutchinson Posted on May 03, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I was trying to start my troybilt little pony ridingI heard a loud bang noise ( metal like) from under hood!! Now all it does is click when I try to start it!! Any ideas ???
Richard Haynes
Level 3:
Master:
  • Master 673 Answers
  • Posted on May 08, 2015
Richard Haynes
Master
Level 3:
Master:
Answers
673
Questions
0
Helped
208379
Points
1403
Remove the spark plug and see if the engine will turn over. It sounds like you may have destroyed the engine.
When my speed queen starts a low quick banging noise is heard. tried low loads but same noise
A Speed Queen top-load washer making a banging sound at the beginning of the cycle could be a sign of a few problems. You could examine the following:
  • Size of load: Check to see that you are not overfilling the washer. The water and clothes should be about 3/4 full in the washer. Overloading the washer can result in the drum becoming unbalanced and making banging sounds.
  • Leveling: Verify that the washer is level. If not, reposition the washer's feet until it is level. A washer that is out of balance can also make banging sounds.
  • Spring elements: Examine the suspension springs at the drum's top. The drum may slam against the washer's sides if one of them has broken or come loose.
  • Motor: The motor might be the source of the banging sound. The washer may vibrate and make banging sounds if the motor is loose or damaged.
I Have A Troy Bilt Pony 42" Deck How Long Is The Deck Belt Inch Wise
Most TroyBilt mowers conveniently have belt part numbers on a label underneath the hood. Enter the part number at TroyBilt parts page https://www.troybilt.com/equipment/troybilt/OwnersCenterLandingView?catalogId=14102&langId=-1&storeId=10001 and it will likely have belt length in the description.
Apr 22, 2019 • Troy Garden
1helpful
I have a Delonghi W130E and last night after about 5 hours of use we heard a loud bang from the machine. I got up and turned the machine off and there was a smaller bang ( noise ) from the machine.
Possible the swinging fins jammed up. Turn it back on and watch the swing. Not very many moving parts. If it's the blower wheel you will know!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Loud thumping from under drivers side that started with a squeal.
16 costly car noises - Bankrate.com
www.bankrate.com/finance/money.../16-costly-car-noises-1.asp...
BankrateYou should not ignore certain thumping, banging, clicking and squealing sounds. These sounds often rear their heads or intensify whenever the driver takes ... Hissing or sizzling under the hood: Heard when the engine is first shut off, .... my rear right wheel makes a loud bang when switching from park to drive/reverse.
Sounds coming from drivers side front wheel - AnandTech Forums
forums.anandtech.com > Social > The Garage
AnandTech
Dec 1, 2009 - 21 posts - ‎10 authors
Sounds coming from drivers side front wheel The Garage. ... slightly left, I get a slight metalish-squealing sound coming from the drivers side front wheel area. ... but before I start the wild and expensive goose chase of bringing it to mechanics I ..... Those twoloud clunks when turning hard right give it away.
Ford Explorer Questions - Thumping from front end - CarGurus
www.cargurus.com > Questions > Ford > Explorer
CarGurusDec 22, 2009 - Thumping from front end - I have a hard thumping noise coming from ... without problem then I'll take a turn or something and it will start. ... I just recentlystarted having a rubbing and thumping and squeaking noise in the right front sidewhen driving ... Thumping sound coming from under the truck 4 answers.
Car Noises: Consumer Reports - Consumer Reports Online
www.consumerreports.org/cro/...noises/.../index.htm
Consumer Reports
Starter suddenly stopped working. Loud bang when
It's most likely a timing problem, you may try too adjust it yourself; Loosen set screw on distributor and get a timing light. there also a chance it jumped a timing gear when you heard the loud bang..
2answers
While I was driving my 1996 Toyota Camry on a highway, it made a loud clanking kind of noise and then the engine stalled. I'm pretty sure that the engine was out of engine oil. But when the car stalled we...
If you ran the engine out of oil then it is done. You car wont just shut off it the radiator is bad. You will need to have the motor swapped. What pump broke?
Loud sounding like loose parts when draining
possibly a coin or hair clip in the pump if not the propeller on the pump may be loose try locating the pump under the machine and try to romove it
4answers
Printer makes a loud clicking noise
Same problem after a paper trapped. I don´t know if the paper trap was because something broke, but after I took the paper the noise started. Please someone give us a solution.
Top Troy Garden Experts
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Renee Knafel-Bullock
Are you a Troy Garden Expert? Answer questions, earn points and help others
