Computers & Internet Logo
Herman Posted on May 03, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to reboot - Computers & Internet
Karl Whisenand
Level 3:
Genius:
  • Master 1,554 Answers
  • Posted on May 03, 2015
Karl Whisenand
Master
Level 3:
Genius:
Answers
1554
Questions
Helped
753176
Points
4266
When you turn on a computer device it will access a tiny startup program, that then searches for a stored operating startup system. in the old days called pulling your self up by your bootstraps .
thats where the idea of booting , rebooting
load bootstrap
load os
load programs
drink coffee
danoyachtcap
Level 3:
Top Expert:
  • Computers & ... Master 2,907 Answers
danoyachtcap
Level 3:
Top Expert:
Answers
2907
Questions
Helped
1275924
Points
52081
If you have windows just select "restart" where you normally shutdown.
Lars Olsson
Level 3:
Brigadier General:
  • Master 3,400 Answers
Lars Olsson
Master
Level 3:
Brigadier General:
Answers
3400
Questions
Helped
1049041
Points
10330
FOR EXEMPLE. ONCE YOU INSTALLS UPDATES
WHEN FINISH WINDOWS WILL YOU DO A REBOOT. (RESTART)
Aspire5250 need to reboot but don't have a reboot disk is there a way to still reboot it
If you don't have a reboot disk, you can still reboot your computer. Here's how:
- Restart your computer.
- Press and hold the Ctrl+Alt+Delete keys at the same time.
- When the Windows Security screen appears, click Restart.
- Your computer will restart without a reboot disk.
tip
How to Reboot a Blackberry Without Removing the Battery?
If you remove batteries and hardware while tinkering with electronic devices, you might run into trouble down the line. Blackberry devices must be rebooted time and again, but you can reboot your Blackberry without removing the battery. <br /> <b><i>Instructions</i></b> <br /> 1. When you install a new program or have a system failure, you must reboot the Blackberry. This is the same concept used in larger desktop or laptop computers. 2. Hold off on using the new program by selecting "Later" instead of "Now" when you are prompted by the Blackberry. This will allow you to wait awhile to reboot your device, especially if you need to use it at the moment and can put off the new program installation. 3. Initiate what is known as a soft reboot by pressing and holding down the key combination of Alt+Cap+Backspace on the Blackberry keyboard. Using this method will also work when the device stalls and you see only the white arrow, but it refuses to move. 4. Note that certain Blackberry models are different and require you to press and hold the Alt+Cap+Delete key combination to reboot the Blackberry without removing the battery. Make sure your keypad is correct for using this method of soft reboot before attempting it. Blackberry makes several different models, and they all operate differently under soft-reboot conditions. 5. Reference your Blackberry manual. Make sure that the keypad soft reboot will work with the specific model you are using. Larger models are typically more prone to working with the aforementioned soft reboot. If this does not work, you will have to use a secondary method. 6. Check to see if you need to install an application for your phone that allows for a soft reboot. Many models, like the Pearl, allow you to download an application for soft reboot. These applications may prevent you from pulling the battery to reboot. 7. Try all the available methods, and if it still does not work, request assistance from your Blackberry dealer. She may know of an alternative or a firmware update for your device. <br />
on Jun 06, 2011 • Cell Phones
Who do you reboot?
I couldn't read the information on the screen.
If you need to reboot, there sometimes a reboot button. Pressing and releasing it will cause the computer to reboot.
If there isn't a reboot button, press and hold the power button until the computer turns off. Release the button and press and release it to reboot the computer.
Good luck.
Paul
Reboot need on Toshiba Satelitte
Rebooting from the Windows OS can be done y a variety of means, depending upon the version of the OS. Clicking the START button or pressing the Windows key on the keyboard will get you to the POWER option where you can select RESTART (which is a reboot).
If you are not in Windows at the time, you can usually press the CRTL-ALT-DEL combo and get a reboot. Lastly, press and hold the POWER button until the device fully shuts off. Wait a few seconds and then power back on to get a reboot.
Firmware
Usually, the Reboot routine is done by holding down the Power ON/OFF button for a while (5 seconds or more) until it reboots. Don't be surprised if it takes a minute or so.
Alternatively, consider using the RESET button ... then do the Reboot routine. Make sure your battery is well charged, remove the SD card, and hold the RESET (pin) down for 20 seconds or so (until the screen shuts off). Then do the Reboot routine.
2helpful
Wont reboot like standard reboots
If the iPad will not reboot using the standard "Hard Reboot" (holding the power button and home button until the iPad restarts.) then I would advise restoring the iPad using iTunes which will set it back to factory settings.
No boot. Continuous long beeps
Remove the following one by one: 1. RAM. Reinsert and reboot. 2. HDD cable (both from the motherboard and from the HDD side). Reconnect and reboot. 3. Power cable from the mother board. reconnect and reboot. 4. Processor. Reinsert and reboot. 5. The 3 connectors from the front basel to the motherboard. Reconnect and reboot.
1helpful
XP Keeps Rebooting at Startup
Most likely it is your hard drive. There is a boot sector on the hard drive and when xp starts it looks for that boot sector. If that boot sector is damaged xp can't find it so xp reboots again...and again...and... Try a different hard drive and see what happens.
Hank
Mozilla firefox keeps asking me to reboot, even when I try to rem
This is due to the registry entries that are installed with Firefox. Any major changes to the system registry requires a reboot. However, a reboot in this case is not immediatelly necessary. You can ignore this error and reboot later if you are working on something, or close out all programs and reboot the computer.
I hope this helps. Please let me know if you have any questions.
Thanks, Raph30
Grand Canyon Tech
Grand Canyon Tech
