Phillips HDTV Projection TV. Colors don't line up create shadow
Phillips HDTV Projection TV. Screen around 43 to 50 inches. Turns on and works, but colors don't line up creating a shadow affect. Yellow and blues don't line up. Can we fix this for a reasonable cost? Can we do this ourselves?
Re: Phillips HDTV Projection TV. Colors don't line up...
Yes sounds like a convergence issue. The following link has convergence repair kits which contain the parts and a cd with instructions on how to do the repair. http://www.tvrepairkits.net/
The tv Magic Focus button don't solved these R,G,B colors lines mis alignments problems.Mean ur tv have a convergence pictures problems,it is dead.Ur tv now have any colors lines like R,G,B mis alignments,have a colors shadows picture or a 3D pictures look alike?Yes,mean ur tv convergence board it is dead to causes all of these pictures problems.The tv convergence board must have to repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
The tv have a problems known as a convergence pictures problems.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board it is dead to causes this problems.The tv convergence board must have be fixed.The tv convergence board must have it parts replaced like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
It sounds like a convergence problem; depending on your skills it may or may not be something you can do (parts cost on EBAY will be under twenty dollars).
I will attach some convergence photos: does your set look anything like these?
If it does and you can solder etc I can tell you the best place to get the parts and how to do it.
Before you rate this information let me know what you find.
Tv have a problems known as a convergence pictures problems,it is dead.Tv have R,G,B colors lines mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board must be replaced to repair it.To solved tv pictures convergence problems.The shop will cost u like $300-350 for parts and labors.
Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture are R,G,B colors lines mis alignments,have colors shadows picture or 3D picture lood alike?The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
Screen looks 3D, wavy, or has a shadow or shadows
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
SOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
SOLUTION
SOLUTION
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
How do I get my Phillips projection HDTV off of 3-D mode?
