Hi, Try cutting the string with a knifing straight clean. Then try again.
It won't go if it is frayed or chewed up. Also make sure you have the correct size of string. Some trimmers only use certain sizes of string to fit the head unit. Good luck.
Testimonial: "my string is the correct size. I need to remove the head, how do I get it apart?"
The string is the correct size. It is stuck in the hole. I need to remove the head to remove the string. How can I remove the head?
