You are right. In a security camera the yellow one is for video and the white one is for audio. You can connect them as accordingly with black wires. The red wire is for the power (+12V) with a black wire. You can connect them also.
TRY THIS AT YOUR OWN RISK!!! On a few cameras I have had apart the black wire is negative and common ground, the red is positive, the yellow is video, the blue wire could be your infra red leds the white maybe audio If your wires have just been cut then why can't you re-connect each wire matching colour for colour making sure you insulate them from each other? I am not sure what voltage your camera works off? but some work from 5 volts and others 12 volts - 24 volts, older cameras may even work from mains voltage, so be very careful with what you are doing always switch off electric supply before making any connections. (make sure your power supply is still ok after having wires cut it may of blown a fuse!) Your best bet is to phone or email the manufacturer for advice. The last resort take the camera apart and trace where the wires go to, then make a note and connect accordingly. This may help to you to get it apart? If you undo the screws on the back cover and loosen off the cable gland you may find that the camera will come apart and the insides will slide out there is usually a rubber seal around the joint of the back plate and main housing. Once you have removed screws and loosened cable gland just gently prize apart. If you can get it apart I would recommend you replace the cable with same type and keep connections inside the camera where they will remain waterproof! I hope this is of some help to you Best of luck!
Hi Thanks
for using FixYa. Please see the link to hook up DVR with camera--- Hookup Camera
with DVR Please do
accept the solution if the issue is resolved or post a comment for further
assistance. Thanks Rylee
red and ground are most likely for 12 volt as you indicated.
white should be your video out which will work with the ground that comes out of the camera.you can connect these wires to a cable that will be termintated with the proper connector at your dvr
I don't know what pins are what on the METRA harness, but the wires coming from the back of the Pioneer unit should be:
black ground red accessory (KEY) yellow memory constant power, blue is remote, orange is for the dimmer, green with black is left rear neg.and green is positive, violet black is right rear negative and violet is positive, white is left front positive and white with black is negative, gray black is right front negative and gray is positive.
If you don't have the pioneer harness (and so these wire colors dont' mean much to you) just message back here, and I'll map those wire colors to pin positions on the back of the unit.
