I have followed the directions in the manual for winding a bobbin, and it wont wind. The thread never catches around the bobbin. The machine was refurbished 10 years ago, and has not been used since. HELP!!!!
Pass the bitter end of the thread from the inside of the bobbin and up through the hole or slot in the bobbin to the top. Hold on to the thread as it turns to get it going.
Do you need to wind a bobbin or place it in the bobbin case for sewing? For bobbin winding, make sure that the top thread is on the spool pin with the appropriate spool holder. Bring the thread under the first thread guide (going from right to left, as you face the front of the sewing machine). Bring the thread around the bobbin winding tension disc so that the thread is under the tension disc. The thread goes from left to right on the front of the disc. Bring the thread to the bobbin and put the thread goes through the hole in the bobbin (from the inside of the bobbin to the outside). Put the bobbin on the bobbin winder spindle and slide the assembly to the right. When the spindle is in the correct position, the needle bar will not move. Hold the free end of the thread above the bobbin and start the sewing machine. After the bobbin has a few layers of thread, stop the machine and cut the excess thread off at the top of the bobbin. Resume winding the bobbin until full (or as full as you need). The machine will automatically stop when the bobbin is full. Move the bobbin winder spindle to the left and cut the thread to separate the bobbin from the top thread. Remove the bobbin from the spindle and thread the top thread back through the guides to the needle.
To place the bobbin correctly in the machine, remove the hook cover plate if you have another bobbin in the machine. Push the release button to the right and then lift the cover up. Lift the previous bobbin out of the bobbin case. Put the new bobbin in with the thread coming off the bobbin counter-clockwise with the hole of the bobbin up. Bring the bobbin thread around the case and into the notch near the front of the bobbin case. Continue to pull the thread lightly around to the second notch. Leave about 6" of thread out past the second notch. Replace the hook cover plate.
Make sure that the presser foot is raised if you are winding a bobbin with the top thread threaded through the needle. Place the bobbin on the spool spindle with the mark (a stylized H) outwards. Bring the bobbin spindle down. Next pull the thread from the needle under the presser foot to the thread guide on the right. Bring the thread above the bobbin and wrap the thread around the bobbin several times. Cut off the excess thread on the thread knife and step on the foot control to wind the bobbin. When the bobbin winding is finished, remove the bobbin from the spindle. Cut the thread to separate the bobbin thread from the needle thread. Move the bobbin spindle up.
You should first make about 10 wraps manually with the thread around the bobbin before putting it on the machine to wind the bobbin--continue to hold the thread tail for a few seconds after you start the machine so the thread will not slip off the bobbin. Some people will put the thread tail through a hole in the bobbin, put the bobbin on the pin and wind with the machine. The only problem with that is if your machine is finicky (like some computerized model), any thread hanging outside the bobbin may cause the machine to malfunction.
Check to make sure the thread path from the spool to the bobbin is correct. The thread should make a loop around a little post that is actually a tensioner that helps the thread wind smoothly onto the bobbin. If something is wrong with that tensioner or the thread is not following the correct thread path, it could cause the thread to not wind smoothly. It appears that your machine has two locations where the spool can be placed to wind the bobbin. You might try using the other option, if one doesn't seem to be working.
Also, you might try slowing the machine down during the thread winding process. It it goes too fast the spool begins bouncing and pulls the thread akilter. Also, some threads will stretch if the winding is too fast causing the thread to "shrink" when sewing your garment and creating puckers.
FWIW, I found that a "SideWinder" stand-alone bobbin winder is a handy gadget. It is available for ~$30 from JoAnn's Fabrics, Amazon, etc and is battery or electric compatible. It saves wear and tear on a machine and can wind multiple bobbins one right after another. Just be sure to verify that your bobbins will work on the SideWinder as some Singer bobbins will not.
if the bobbin thread is winding around the bobbin winder spindle then the bobbin is not sitting correctly on the bobbin winder spindle,, the bobbin (metal or plastic) should lock in on the bobbin winder spindle & the the thread should be around the bobbin tension guide
Which Singer machine do you have? I know how to wind and insert a full bobbin for some models.
Some wind the bobbin with it in the case. This is the case with my Touch & Sew. Inserting a full bobbin is simple. Open the slide plate and drop in the bobbin with the rings up. Make sure that to hold the bobbin thread so that it comes off at the left. Then close the slide plate and make sure that the end of the bobbin thread is coming through the notch. Hold onto the threads and turn the handwheel until the top and bottom thread come back up with a twist. To wind a bobbin for this machine, open the slide plate (some models have a little mark to line up the slide plate). Put in the empty bobbin and thread the top normally. Set the machine to straight stitch and push the bobbin wind button in. (This has a bulls-eye symbol on it.) Wrap the end of the top thread around the presser foot screw several times and hold onto the end. Step on the foot control to start winding. Keep winding until the bobbin is full. The thread wound onto the screw should break. Pull some extra thread and cut it to separate the top and bottom threads. Close the slide plate and set your desired stitch.
Other models are wound at the top of the machine. For some of with a drop-in bobbin, you need to bring the thread down to a catch and then off to the left to another catch. Some have a vertical bobbin. I don't remember if they all have a removable case. Those that do need the thread to come through a notch on the case that pulls the thread under a spring that keeps the bobbin tension. However you should check your manual. If you do not have a manual, check if one is available online. (http://www.singerco.com/accessories/instruction-manuals has many of the Singer manuals for sale or download.)
If you post a comment with the model of your machine, I'll give you a description of threading the bobbin or winding one.
When you wind a bobbin on a Husqvarna and you leave the machine threaded to wind the bobbin through the needle, you must take the thread down below the foot (a metal foot only) before you take the thread up to the bobbin winder. If you take the thread directly from the needle it creates too much tension on the thread and crushes the center of the bobbin so that either you can't get the bobbin off the spindle or in some cases it damages the bobbin completely.
Some threads, the kind that can stretch slightly when pulled, shouldn't be wound through the needle at all. Instead go through the first guilde and then straight down to the little metal "button like" guide and then to the bobbin. It will create much less tension on the thread and wind it much better.
I just figured out why my bobbine was winding on shaft instead of on the bobbin. first of all make sure the bobbin is setting up high enough, top of bobbin needs to be a fraction higher then the bobbin shuttle, next check to make sure there are no burrs on the bobbin, then make sure that the thear is catching in the groove (**** in top) of the bobbin. In order to get mine to wind i had to lett the tread go down and then slip the thread in the groove. also remember to leave the pressure foot up do not put it down. let me know if this helps.
I have a Kenmore as well ,I hope that this will work for you ,too bad that I don't live close to you otherwise I would give a hand. This is the way I fill the bobbin on mine.
Mine is located on the top right ,I put the thread into the bobbin hole leaving a small piece of thread hanging for me to hold when I begin the winding, I pull the wheele out to stop the needle from moving while winding, when I am done just push it back in .I run the thread from the spool into the top left it looks like a U turn with a screw go around that without winding just pull it into the bobbin hole. press the foot control and it will begin winding .
