To clean a squirrel cage fan properly it needs to be removed from the air handler. 2 or 4 screws and disconnect wires and remove blower assembly. Loosen screw holding squirrel cage, take the 3 screws loose holding the fan motor in the blower housing, and remove the motor.
Then remove the screws in blower housing, usually 2 and remove the blower wheel.
Clean and reverse the process.
Squirrel cage style fan blades can be cleaned by running... a small screw driver along the inside lenth of each fin, scraping off dirt, ling and stuff. The thing to watch for is to not remove any clip from the fin, it is a balancer, and to not rough handle the fan or it may warp if it's metal.
After scraping, remove all scraped materials by vacuum or other means and when the fan starts up again, it will create a dust cloud for the cleaning process.
Use a vacuum cleaner, the small round end.
