Protocol questions - for more vivid mental image.
The logon screen, is it a 'classic logon' screen? IE do you get the option to enter a username and password or do you click an icon and then are prompted for a password?
Scenario 1
If not, you can use the logon 'panic button' = use Ctrl+Alt+Del trick {Ctrl+Alt+Del pressed twice} to make sure you get two fields to fill so that you log on as the
Administrator. IE username = Administrator
password = {leave blank} Press enter and if you gain access, proceed to the Control panel or run | compmgmt.msc | local users and groups. From users, rightclick your account and then set password. Set the password, remember it, logoff and then logon with your credentials.
Scenario 2
Please take note this tip (if it works) is intended to
regain a forgotten Vista Administrator password. It is
not intended to illegally hack into a Vista system that’s not owned by you.
- Reboot the Windows Vista and boot up with Windows Vista installation DVD.
- While the Windows Vista installation interface pops up, click the Repair You Computer link at the bottom-left corner.
- Next, the System Recovery Options dialog box appears. There are few options but we want the Command Prompt option. Click on this option now.
- In the Vista Command Prompt, type mmc.exe and press the ENTER key to bring up the Microsoft Management Console.
- Click on the File menu, select Add / Remove Snap-in option, locate and select the Local Users and Groups on the left panel, and click Add button to add it to the right panel.
- Now, the Choose Target Machine dialog box pop up. Ignore this by clicking the Finish button
- Click OK button and return to the MMC window (the first window that showed when you entered mmc.exe). In the left panel, double-click Local Users and Group that was added in step 5. Click on User folder, locate and right-click the target Vista logon account whose password you need to set.
Guess you should know what to do now. Select the
Set Password from the right-click menu to set a new password / reset old password.
Scenario 3
There is software out there than can do all the leg work for you like - NT & registry editor. Careful though. Can render your system useless if you don't know how to use them.
dimenticata password richiesta all'accensione del pc.
Tolto batteria di alimentazione bios.
al riavvio si visualizza errore 162-system options not set
The following configuration options were automatically updated:
Disk 1 type: 65......
cmos checksum invalid, default values loaded
F1 save changes F2 ignore changes
i forgot my password BIOS...
How can i RESET that Password??
Help me...
Gigabyte GA-945P-S3 Motherboard
i forgot my Password BIOS
pls help me...
log on to windows xp
forget password
