From the the attached photo I see that you have completely disassemble the tape. This makes the tape almost impossible to reassemble. The spring has to be back wound fully, the blade attached and retracted back into the case using the back wound spring. This requires special equipment that is not overly complicated, however not possible to make for a once off use. I have designed, built and trained operators to use this type of equipment in a production situation, however in my 35 years of experience I have never been seen anyone back wind a spring by hand. Sorry to say but the tape is ready for the trash.
You don't need to open it to replace the blade. You pull the blade all the way out and you will see that it is hooked to a spring. All you have to do is unhook the old blade and connect the new one and slowly let it wind back in. Remember to hang on tight to the spring so it doesn't snap back in before you get the new blade connected. If you do need to take it apart, there should be screws holding it together.
Did it break and go flying up inside there? Take it back where you bought it, tell them you want a new one, they will replace it, all Stanley tools are warranted, the dealer may not want to do it, but he has to. You will never get it right by replacing the blade. I take that back, you might get it right.
Pull it all the way out ... have a nail ready to put into the hole just past the end on the tape, in the spring. Remove the tape. Install the new one (insert the tang into the hole and twist). Remove the nail and carefully allow the spring to pull the new tape in.
No. You'll have to replace the tape measure, or find another similar model to rob the part from...See here and here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
