Tip & How-To about Sony Televison & Video
Service menu codes sony
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes.
# Using the remote control:
# Turn the TV off.
# Press {DISPLAY} {5} {VOL+} {POWER ON} buttons.
or
Press {DISPLAY} {5} {POWER ON} buttons.
# The Service Menu will be displayed.
# Use numbers {1} and {4} to select the item to adjust.
# Use numbers {3} and {6} to adjust the value of the data.
# Press {MUTE} then {ENTER} to save new settings.
# The words "WRITE" in red will show up in the upper right corner if saved.
# Turn the TV off to exit the service menu.
Televison & Video Logo
I need a service menu code for a rca sld58g45rq tv.
* Turn the TV off.* Press simultaneously the {MENU} {VOL -} {CH -} buttons for about 8-10 seconds.
* The TV will turn on with the Service Menu displayed.
* Press the {POWER} button to exit. thank you..
I HAVE CHANGE MY TV EPROM I NEED TV CODE TO SETUP
NOTICE: MUST READ BEFORE USING SERVICE CODES!!! RiddledTV.com provides this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes. * Unplug the power cable. * Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet. * Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed. * Use the {CH+} {CH-} buttons to select menus. * Use the {VOL+} {VOL -} buttons to change settings. * Some menus might have sub-addresses. Use the numeric buttons {0} to {7} to adjust sub-item data. * Press the {MENU} button or turn the TV off to exit.
UNABLE TO RECONNECT WITH SERVICE ON TV
Hello
You wants to get into the service mode of JVC tv, I thinks from your ad and powts this solution.
To get into the service mode of most of JVC TVs do the folloing:
This information is for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes.
Press the {MENU} button and go to the User Menu screen, make sure
that the indicator (arrow) is pointed and highlights the "Picture Control".
- The buttons on top of the remote are set to TV & VCR respectively.
- Set sleep timer to "0" minutes and while it is displayed, simultaneously
press the {VIDEO STATUS} & {DISPLAY} buttons.
- The main service menu will be displayed with choices #1 through #9.
- Press one of the corresponding number keys to enter that menu.
- Use the {CH+} {CH-} buttons to navigate within a menu.
- Use the {VOL+} {VOL-} buttons to change the values.
- Use the {MUTING} button to memorize the changed value.
- Use the {BACK} button to exit the service menu.
NOTE: If you are not qualified and familier with adjusting service mode adjustments, Please don't get into it.
OK
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
