Check the pump filter which could be blocked or something like a nail has jammed the pump impeller. this may cause a mess as the water needs to be drained to access the removable cover to gain access to the filter/impeller.
Also check the drain pipe is not blocked. this can also be used to drain the machine into a bucket manually.
Na OE error is something in the inner drum
a doggy do bag or some plastic wrapper etc
you can take the mains supply and water and drain off
lay the machine over on the side opposite the soap drawer
so no chance of spills
then check the filters etc
some plyers and gas glamps to release the pipes if needed
check every drain
will take some time
when you find the issue with the drain youll know it
but checking the pump alone is never a fix
you must check inside the drum skin
either look inside the drum side of the pump feed
or take the heating element out and visually inspect the drain to pump inside the drum
all sorts of crap ends up between the wash tub and the drum skin
not all of it ends up in the pump
so diggy bags this week ive take 3 machines with 5 bags
{and £4.50 in coins}
Hello & Welcome to FixYa
OE is a drain error and is displayed when the
washer is unable to drain water. Please check the drain hose and drain pump
filter for any clogs to clean the error. Please get back to me if you have any
other questions.
Kevin
