Konica Minolta bizhub 250 All-In-One Laser Printer Logo
Posted on Jul 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a BizHub C253 and the data light just flashes. NOTHING prints ??
Anonymous
Level 1:
New Friend:
  • Contributor 51 Answers
  • Posted on Sep 17, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
51
Questions
0
Helped
94240
Points
90
Anonymous
Level 1:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Jul 11, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
0
Helped
10135
Points
14
Your machine have a low level firmware... you need to flash your machine.. with a updated version...
Anonymous
Level 2:
  • Konica Minolta Expert 158 Answers
  • Posted on Oct 03, 2009
Anonymous
Level 2:
Answers
158
Questions
0
Helped
186202
Points
319
Most common cause for this is the hard drive in the copier is malfunctioning and needs to be replaced or data clear needs to be done in service mode
1helpful
Bizhub C450 strange printing problem. Green data LED is flashing but nothing happens.
Did you try to change the IP address of MFP. Please change IP address of MFP and connect the PC you are sure not giving any problem. If its works fine then connect rest of the remaining PC's
Bizhub c253 error code c4151
Motor inside the print head for cyan image unit is bad, Print heads are located below the image units one for each color. will need a tech to replace.Open close front door to reset
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2helpful
2answers
How can I solve error code c255A
From another site
Details Subject:
C-255A (C255A), C-255B (C255B), C-2559 (C2559) or C-255C (C255C) at power up.
Description:
C-255x code at power up.
Solution:
CAUSE: The K (black) IU (C-255C) has failed. The M (Magenta) IU (C-255A), Y (Yellow) IU (C-255B) or C (Cyan) IU (C-2559) is not fully seated or has failed.
SOLUTION: Replace the K (black) IU (Item #A0DE02F for the bizhub C203/C253 and Item #A0DE03F for the bizhub C353). Reseat the color IU and if the problem persists, replace it. Item # Color IU Model
A0DE0CF Magenta bizhub C203/C253
A0DE0DF Magenta bizhub C353
A0DE06F Yellow bizhub C203/C253
A0DE07F Yellow bizhub C353
A0DE0HF Cyan bizhub C203/C253
A0DE0JF Cyan bizhub C353
SPECIAL NOTE: Solution contribution by Tom Kelly, Workgroup/SSD
Options:
None Specified Details Subject:
After toner installation, C255x code within a few hundred prints.
Description:
C2551, C2553, C2555 or C2557 codes.
Solution:
CAUSE: Toner is not supplied due to abnormal position of coupling.
Normal condition The coupling is blocked by bracket
When a print job is sent to my Konica Minolta Bizhub c352, it only flashes "data" light, but nothing prints.
Does this happen when you copy. Try different document and program pdf word web page etc. Static IP or DHPC? Recommend static IP for copier/printers
Hi Kenneth,
This can be a number of reasons.
When you go into the job list and look at the job history, Is there an error message saying "Deleted due to error" or something similar to this in there?
If it does, highlight the job and select "Details" to the lower right and please post what the "Error details" are.
Printing on A7 envelopes using Bizhub C253
does A7 show up on the as a option on the manual bypass does it show up in your printer properties??? if not measure the envelope and tell the copier with and length try that option
Bizhub C253 "Id & Print" on Mac OS X
Ok this might not be much help but there is an option in the menus to 'print without authentication' you need to go to the control panel on the copier, press the utility/counter button to the right of the touch screen, press administrator settings for which the password is 12345678 then press number 4 user authentication/account track, then number 4 print without authentication, if you turn this option on it will allow you to print from mac, you will need to confirm this with whoever checks the account track as it may not then monitor any of the print jobs. Hope this helps
Printing from Adobe Illustrator
Try to retarget work of your printer under your type of the used paper. Such parameters as density of the paper can have important importance. Try to print one and that document on miscellaneous type papers
2helpful
2answers
Printing accurate colors from Corel draw to the Minolta Bizhub C252
HI there i have the same printer and for accurate color i follow this steps:
1 - First publicate you work in a pdf file whit high quality
2 - Go into adobe Acrobat (profesional not reader only) and pres print
3 - Then you have to select in advanced settings and select icc profile "sRGB ..."
4 - You´ll notice that the colors are very real. No oversaturated and the real deal are the fonts that prints correctly in border even if they are very small (- 6 pt.).
5 - RECOMENDATION: For intense black use a compost one 100% in every color or select in the color palette the one at the end of the palette
Greetins.
Nolasco from argentina - DPI Grafica
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
