Mach Speed TRIO Stealth G2 10.1" 16 GB Wi-Fi Black Tablet Android 4.0, LCD Touchscreen Logo
M
Mary K Gerr Posted on Apr 28, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will not down load apps. Lost all data, want to reload to orig factory settings
Talked to support, they say there isn't a way to reload fact data?
spy1309
Level 2:
Sergeant:
  • Expert 333 Answers
  • Posted on May 14, 2015
spy1309
Expert
Level 2:
Sergeant:
Answers
333
Questions
0
Helped
78015
Points
707
You got one of those no name chinese made tablets, if the reset to factory defaults it is not working there is a slim chance to load a new firmware.
I keep getting kicked out of certain game apps on my Samsung galaxy tab e. How do I fix this problem?
First, I'm not a Samsung tech.
* I get problems downloading new apps or unable to get updates.
* Found that the tablet (or phone) memory gets filled and slows down every thing. It won't self clear memory even when you ask it to.
* Go to settings, Apps, then check the memory cache and clear them.
* This also means your internal memory is packed. (or too small). Clear or upgrade memory for more space.
https://www.verizonwireless.com/support/knowledge-base-178690/
* you may need to do a "Hard Reset" to clear all the unwanted junk off the device. Check your settings for a "factory reset" option. Sometimes called a "factory restore"
* Be sure to back up your device before the reset. Or transfer the data to the "cloud drive" , SD card.
* Reload the current operating system (Android or similar).
* Only reload the apps you really need. Leave the rest of the junk in the "Cloud" This way you still have usable memory.
* Hard reset; https://www.youtube.com/watch?v=aZpCyz6EFME
* Hard reset and bypass Google; https://www.youtube.com/watch?v=uDSrChQxQ_o
* Factory reset (Hard incl.); https://www.youtube.com/watch?v=TILb8CpvAYk
* Still have problems? Check your warranty. Call for service.
Aloha, ukeboy57
Reset zte maxx
Master reset from settings menu
A master reset restores the original factory settings and may delete your personal data on the internal storage, such as downloads, ringtones, images, apps, contacts, and Visual Voicemail. It does not delete data stored on the SIM card or SD card.
  1. From any Home screen, tap the All apps icon.
  2. Tap Settings.
  3. Scroll to the 'PERSONAL' heading, then tap Backup & reset.
  4. Tap Factory data reset.
  5. Tap Reset phone.
  6. If your phone is password protected, you'll be prompted to enter your Pattern, PIN, or Password.
  7. Tap Erase everything.
Master reset with hardware keys
If the device menus are frozen or unresponsive, you can master reset using hardware keys.
  1. Back up data on the internal memory.
  2. With the device turned off, press and hold the Volume Up and Power buttons until the ZTE logo screen appears, then release.
    Press the Volume down button to highlight wipe data/factory reset.
  3. Press the Power button to select.
  4. Press the Volume down button repeatedly until Yes -- delete all user data is highlighted.
  5. Press the Power button to select.
  6. Wait as the device resets.
Can't remember unlock pattern for Hisene tablet
You probably will have to factory reset your device. See typical instructions at How to factory hard reset Hisense sero lite tablet .
Be aware-A factory reset erases any data files that you have stored on the device, and you will have to reload any apps that you have added to the device previously.
Want to erase password and start over
n order to reset to factory settings, please follow these instructions :
- Power off machine.
- Hold down + first and then POWER for about 10 seconds, release both buttons once Kurio screen loads .
- When you get the open Android picture, press + to enter menu, use - to move down to "wipe data / factory reset" and press POWER again to choose.
- Next press - to choose "YES" and press POWER to start reset.
- Check for yellow text Formatting /data, formatting cache, Data wipe complete.
- Choose reboot system now and press POWER to complete process.
NOTE: This will erase data from your Kurio's internal storage such as Accounts, System settings and Downloaded apps. But music, pictures, and other user data won't be erased. Check "Erase SD card" if you want to clear all the data of the system.
It is also possible to reset only the Kurio Interface: Go to Parental area > Tablet Setup> Press "Reset the Interface to Factory Default Settings".
Once this has been done you will need to set the device up and perform all the updates, instructions for this are on this page.
1helpful
My tablet has seemed to have lost all data there are lines of colrs only I did not drop in fact it had been sitting in its case for a week with no use drop either
If a power off/on or a full factory reset don't work, then you have a warranty claim to make!
Press down the Power button and tap Volume Up as you startup the Jazz and you should see the Android system recovery menu appear on your screen. Choose the `factory reset`. All data will be wiped, all settings erased - so back it up first!
1helpful
2answers
There are no instructions on how to reset my grandsons kurio7s tablet
check out http://www.kurioworld.com/k/us/parents/support/7/gettingstarted
Kurio7s
In order to reset to factory settings, please follow these instructions :
Please feel free to contact Kurio Technical Support on our support page.
Forgot password and password
Now you have a problem. You won't be able to log in. Most non Apple tablets you can reset and put to factory settings. Then you have to install all apps again. All your data will be lost.
Just write down all passwords you used last year and try them one by one, if you done want to lose the data (and save time setting up all apps.
If you want to know how to set to factory settings.please type the brand and model here, also give the OS details it i running on.
Parental Control / Reinstall pre-loaded apps
Very upsetting, I agree! I factory reset yesterday and lost all my preloaded apps, the only way to get them back is to call tech support and have them do it. Unfortunately the number has been busy all day and tabeo website has been down on and off all day today. I will try again tomorrow. Good luck!
Top Mach Speed Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Mach Speed Tablet and eReader Expert? Answer questions, earn points and help others
