K
Kathy Posted on Apr 27, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cleared a paper jam. Why does the printer still indicate a jam and won't print?
David Payne
Level 3:
Top Expert:
  • Office Equip... Master 14,162 Answers
  • Posted on Apr 27, 2015
David Payne
Level 3:
Top Expert:
Answers
14162
Questions
0
Helped
2998275
Points
455836
Harrie
Level 3:
Top Expert:
  • Office Equip... Master 6,746 Answers
 Harrie
Level 3:
Top Expert:
Answers
6746
Questions
0
Helped
1285780
Points
83153
When the paper sensors are sensing things what should not be there, or one or more sensors are defect you get the message again. Could be the logic board is not getting correct signals, or the logic board is defect, Just to mention a few possibilities for this message.
Not knowing what printer you have, be aware, most printers are cheaper then the ink they are coming with, so most of the time it is better to buy a new one than to repair.
But first check is nothing fell into the printer. Like a paperclip or a little shred of paper on a place it should not be.
After what I already found in "defective" printers, I will not be wondered for whatever you find. Lots of "defective" printers were cured, after I remover the obstruction.
Success
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Paper jams at toner cartridge, printer service maintenance kit installed
Paper Jam clearing: copy and paste the link in your web browser...I used to work with these printer's..when they work great, when they don't, not so great..
https://www.manualslib.com/manual/949165/Hp-Laserjet-5000.html?page=84
Clearing Paper Jams If the printer's control panel displays a paper jam message, look for paper in the locations indicated in Figure 22, then see the procedure for clearing the paper jam. You might need to look for paper in other locations than indicated in the paper jam message. If the location of the paper jam is not obvious, look first in the top cover area.When clearing paper jams, be very careful not to tear the paper. If a small piece of paper is left in the printer, it could cause additional jams. If paper jams are a recurring problem, see page 78.(A paper jam message might also display if the rear door is open.)
The top cover of the printer must be opened and then closed to clear a paper jam message.Paper jams can occur at the following locations:Output areas(top and rear)Go to page 75.
Loose toner might remain in the printer after a paper jam, but thetoner should clear after a few sheets are printed.
Brother 540cn Printer won't print and displays unable to print 50. The photo capture button also flashes
The error code 50 indicates a paper jam condition. Whether there's actually still paper jammed or not, it's sensors are still indicating a jam. Check again for a bit of paper, or there may be a faulty sensor.
Check out this link: Brother for further information.
Printer won't print after clearing a paper jam
I use to have an HP All-In-One Laser Jet printer that, for reasons unknown to me, wouldn't print after clearing a paper jam until I replaced the ink cartridge.
Paper feeds about half way and then stops. All of the indicator lights come on.
If you get a paper jam, the Paper Jam indicator light promptsyou to clear the paper path. If the paper has just started to feed from thepaper feeder when the jam occurs, pull the paper straight up out of the paper feeder. Open and close the printer cover toresume printing. If the paper jam occurs inside the printer, remove the paper from the output bin. Turn the printeroff, then on. If this doesn't clear the jam, open the printer cover.Remove the print cartridge and cover it.For additional assistance, please contactLexmark Technical Support
2answers
The red and green lights are flashing continously and it won print
The lights continually flashing indicate a paper jam or the printer being out of ink. Check/clear any paper jam and verify the ink cartidge is set correctly.
1helpful
Lexmark t640: paper jam in the back door. I can see the edge of the paper. How do I release the tension on the rollers so I can slide it out? Now it is in there tight and to grab it just tears off a piece...
Hope this helps....
Explanation of the paper jam message
A 241.09 Paper Jam message indicates that the printer thinks a sheet of paper has jammed at the front of the printer. The jammed sheet of paper is most likely to be found in one of the paper trays or under the toner cartridge.
NOTE: If you select Show areas on the operator panel, you can view one or more images to help you locate and clear the jam.
Clearing the jam
To resolve the paper jam message, you must first clear the entire paper path. To access the jam area, you will need to open one or more of the paper trays. Follow the steps in the table below to help you locate and clear the jam.
Step Action Image 1 Open the printer paper tray (tray 1), and remove any jammed media you find there. pattlnk_10222007_1922-enus28872_24109paperjam1_t64x_en_us.gif 2 Open the front cover and remove the toner cartridge. Examine the area inside the printer and remove any jammed media you find there. pattlnk_10242007_159-enus28872_24109paperjam5_t64x_en_us.gif 3 If you have a duplex option installed, also remove the duplex access tray and remove any jammed media you find there. pattlnk_10302007_1559-enus28860_24x17paperjamduplex_t64x_en_us.gif 4 If you were printing from an optional paper tray, such as tray 2 or tray 3, open any optional trays, starting at the top, and remove any jammed media. Pull the print media either up or down. If it does not pull easily one way, try the other way pattlnk_10222007_1957-enus28872_24109paperjam3_t64x_en_us.gif 5 If you are printing from an optional 2000-sheet feeder, open the front door. Press the elevator button (A) to lower the tray. Remove any partially fed media from the feeder.
NOTE: Make sure the stack of print media is straight and pushed all of the way into the feeder. Incorrectly loaded paper is the most common cause of paper jams from a 2000-sheet feeder option.
For a larger image, click here. 6 Finally, reinstall all of the paper trays and press the pattlnk_10222007_2117-select_button.jpg button to try printing again.
NOTE: You may receive a different paper jam message informing you that another sheet of paper is jammed elsewhere in the printer. If this occurs, the error code will indicate the location. Click here for a diagram showing the error code locations. The paper path will vary, depending on the paper source and number of paper feed options installed.
Remove any jammed sheets of paper you find and try printing again.
Paper LED Blinking
Did you see http://www.fixya.com/support/r310860-lights_indicate
The Paper LED is flashing.
papereroor2.gif Meaning of LED Indication
Front cover is open:
Close the front cover of the printer.
Back cover is open:
Close the back cover of the printer.
Paper jam:
Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the Go button.
No paper fed manual feed slot:
Put the paper back in the manual feed slot.
Memory full:
The printer memory is full and the printer cannot print full pages of a document. To solve this problem, click here.
Print overrun:
A print overrun occurred and the printer cannot print full pages of a document. To solve this problem, click here.
Clean drum unit:
The corona wire needs to be cleaned. To see how to clean the corona wire, click here.
k24674
ADMIN Andrew
ADMIN Andrew
