Here is a link that helped me out Subwoofer wiring diagrams
if that doesn't help look around that site they have some great info there
good luck
SOURCE: 2006 12" Kicker L7 4 ohm
first whats the range in terms of WATTS that your 12" sub can handle in 4 OHMS ? second , lets check the AMP , POWER ACOUSTIK 1800 WATTS , Now thats a lot of power to drive a single 12" sub speaker . your amp is 1800 watts , per channel is around 500 watts , if BRIDGE thats around 1600 watts rms for ONE channel , if your sub can handle that kind of wattage fine , but it will not blow the amp , what it does is shuts down , some kind of protection mode , it will come back on after a minute or so. I suggest to use one channel in stereo mode , or purchase another sub to use the other channel. i hope this helps AJ
SOURCE: Wiring
hi!well i think you should use both channels.because if you'll use both channels then u'll have high power to your subs.i have tryed it and i prefer you use both channels.
SOURCE: directed 1100d 2-channel amp
well the 1100d directed amp is a mono block.... but yes tou would run them in series which is pos 2 neg on each speaker if there 4 ohm and if there 8ohm run it parrel pos 2 pos neg 2 neg....
SOURCE: amplifier loads
Hello ronnieyannon,
A single 4 ohm speaker wired to each channel, like you have them wired, presents a 4 ohm load. And it appears that you have them connected properly. The 401s is only stable to 4 ohms when bridged, so if you were to parallel the 2 4 ohm subs in bridged mode, the load would be 2 ohms and the amp would most likely overheat and go into protection.
I'd wire them the way you have them wired.
Each channel of the amp outputs only 100 watts into 4 ohms. That is adequate for regular full-range speakers, component speakers, mid-range drivers, and even some small subs. But it is a little low on power for most subwoofer applications.
Hope this helps.
SOURCE: need manual for mtx audio thunder 4501
Hello
Get into this link. You can download the user manual to your device from here. OK.
caraudio.manualsonline.com/manuals/.../mtx_audio/mtx_audio_car_s
