First Option: mostly nokia chargers doesn't make problems... just try the following.. connect ur mobile with a system (usb cable)... found out whether it is charging or not... if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)... if it charged with usb cable buy a new charger Please change Phone Bettery and check the charging IF Charging Problem not Solved So
Second Option: Your Phone charging IC Fault So Please change charging IC And charging Problem will Solved Quickly
there are few options by which this problem may rise .
* Old battery will not charge if its bulged. so get new 1
* Check if the charging plug in side th mobile has not broken.
* There mite be a short connection with the pin which will not charge the battery.
* take battery out keep it in sun for 5 mins and use it.or rub in 1 direction. mite work.
* If there is a problem with the board , check below
Secend Option: Your Phone charging IC Fault So Please change charging IC And charging Problem will Solved Quickly
If your phone is not charging, try use a similar charger
to charge to see if it is charger problem, if the similar charger did
not charge your phone, it means the problem is the charging port on your
phone.
The charging port of your phone is bad and will need to
be replace. Replace the charging port on your phone to solve the problem
of your phone not charging. Once the charging port is replaced, the
not charging problem with your phone solve.
